Hardtop Fixing
Posted 01 September 2009 - 09:10 PM
Posted 01 September 2009 - 09:12 PM
Posted 01 September 2009 - 09:13 PM
Posted 01 September 2009 - 09:38 PM
1. I have never been entirely happy with the way the rear clips attach, it always seems like a poorly designed way of attaching so am I doing something wrong? does anybody have a pic of the rear clips attached?
TIP
I have just fitted my hardtop aswell and I don't remember one of the rear fixings being hard to go on in past years! One side fits perfectly but the other seems to be out of alignment slightly. Tightening the bolt makes the bracket stick out a bit at the front.
Guess I'll just try to add foam to stop that bit squeaking anyway
Posted 03 September 2009 - 08:25 PM
Posted 03 September 2009 - 08:47 PM
Posted 03 September 2009 - 09:09 PM
Posted 03 September 2009 - 09:55 PM
the EBC pics are not very clear
can anybody post a pic of these new plastic clips
TIP
EDIT- the security torx bolts on mine were not on too tight so I managed to loosen and adjust with a pair of pliers (did scuff them a bit though)
have found this
bracket
but does not show that clearly
Edited by TIP, 03 September 2009 - 10:01 PM.
Posted 04 September 2009 - 08:21 AM
Edited by Steve B, 04 September 2009 - 08:22 AM.
Posted 04 September 2009 - 09:21 AM
Posted 04 September 2009 - 10:18 AM
Posted 04 September 2009 - 10:32 AM
My hard top used to rattle and squeak like mad. Its seems to be the cup part of the bracket rattling around and somebody suggested I put some velcro around the cup and sit the roof bracket into it. In other words you dont have metal aginast metal. But the velcro aournd the cup bracket and thihted the roof into it.
It works a treat and no squeaks at all.
I've done a temp fix with bike handle bar grip cut to shape. doesn't fix the roof sitting to high for the windows though
Posted 30 September 2009 - 01:30 PM
Just ordered the parts from Vauxhall as the Nearest Lotus Dealer is a 60mile round trip, where as the Vauxhall dealer 1.5 miles away. Part numbers from wiki 9197328 & 9197327 £49.50
Just finally collected them from Vauxhall. Had someone on parts reception mess me about for 40 minutes saying "I can't find them"
Hope they make everything fit nicely now
Posted 30 September 2009 - 01:39 PM
Posted 30 September 2009 - 01:47 PM
The windows might still need to be adjusted to meet the hardtop. There is a small metal disc as part of the scissor mechanism that will need to be loosened and rotated a few degrees. Check the window adjustment guide for more details.
Cool,
I think fingers crossed they maybe ok as the only problem was the hardtop was sitting about 5mm too high, if the new brackets drop it straight down the seals should meet up perfectly -
Posted 30 September 2009 - 02:15 PM
Anyway, you have them now - and I still don't!
Let us know if it sorts your problem. My HT squeaks are doing my head in!
Posted 30 September 2009 - 09:25 PM
Edited by cerbera8, 30 September 2009 - 09:26 PM.
