Rusty Wishbones
Posted 03 September 2009 - 02:12 PM
Posted 03 September 2009 - 02:14 PM
Posted 03 September 2009 - 02:21 PM
Posted 03 September 2009 - 02:34 PM
Posted 03 September 2009 - 04:11 PM
Posted 03 September 2009 - 04:21 PM
When you say zinc coat, are they safe to galvanise, or can you only plate them
You can get zinc electroplated on if thats what your after.
Posted 03 September 2009 - 04:40 PM
Posted 03 September 2009 - 04:48 PM
Posted 03 September 2009 - 04:52 PM
Posted 03 September 2009 - 05:33 PM
I don't really want to compromise strength
I may try and get hold of a bent one to do some experiments withAnyone got one lying around they don't need
You can always have my 'rusty' ones if I decide to have them replaced!
Posted 03 September 2009 - 05:35 PM
You won't need them replacedYou can always have my 'rusty' ones if I decide to have them replaced!
(you do realise it will be ~£1600 for the wishbones, and prob about £500-1000 for fitting
Posted 03 September 2009 - 08:59 PM
Posted 03 September 2009 - 09:03 PM
Posted 03 September 2009 - 09:13 PM
Posted 03 September 2009 - 11:51 PM
Posted 04 September 2009 - 07:39 AM
yes i have and ready to be sent if needed lol
Posted 04 September 2009 - 11:33 AM
Those are good prices, esp with everything you need pre-installedEliseparts now sell VX220 wishbones with a choice of bushes and the ball joint pre-installed. Look nice and they are cheaper than Vaux.
So £1334 all in, which still sounds a lot but...
Shotblast old wishbones ~£80
Zinc Plate old wishbones ~£100
Paint old wishbones ~£80
8x Ball Joints £160
Ertalon Full Bush Set £200
So it's ~£600 to fully 'refresh' the existing set, and with the pain of fitting them; you could also sell the old ones on
Posted 04 September 2009 - 04:55 PM
Posted 05 September 2009 - 09:56 AM
These are a very high specification replacement wishbone.
The tube used is a top quality CDS (Cold Drawn Steel) instead or ERW (Electrically welded tube).
CDS is inherently stronger than ERW as there is no seam so we can reduce the wall thickness without reducing the strength .
In fact our wishbones are slightly stronger than the original but not to the extent where the chassis could get damaged prior to the wishbone as you want the “weakest link†to be a relatively cheap part to replace should you have an encounter with a kerb or large pot-hole.
All of our wishbones are TIG ( Tungsten inert gas) welded rather than the messy MIG (Metal Inert Gas) which forms a stronger bond to the metals and gives a cleaner pristine finish.
TIG welding was introduced within the aircraft industry some 60 years ago and still is used in this industry and in F1 race technology today (albeit with much more modern machinery and consumables).
TIG welding is less prone to stress cracking and distortion whereas MIG welding can cause porosity which can weaken the joints.
This takes more than twice as long to TIG weld the wishbones but we think it is worth the extra benefits TIG welding gives.
Once the wishbones have been welded they are then lightly bead blasted to give a nice key for the black powder coat finish.
All of our wishbones have new ball joints pre installed and we also offer the option of 3 types of inner bushes ,Original rubber, polyurethane or ertalon.
Posted 06 September 2009 - 03:38 PM
8x Ball Joints £160
Where have you been getting your prices?
my wishbones cost me £80 to be blasted, then zinc primed and powder coated.
