Anyone Know How To Reset The Airbag Light?
20 replies to this topic
#1 d4nnyk
d4nnyk
  • 769 posts
Posted 14 September 2009 - 01:17 PM
well I finally got my OP-COM to talk to the ECU, but how do I reset the airbag light?? If I go through the airbag option I can reprogram the airbag, but is this what I want to do??? Has anyone done this before??
#2 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 14 September 2009 - 01:23 PM
Have you fixed the fault that caused the light to come on? DG
#3 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 14 September 2009 - 01:27 PM
Glad you finally got OP-COM to work - what was the problem in the end?
As far as I remember, I thought you had to clear the error messages...
OP COM info on VX220.org WIKI
In the install CD there is a pdf on Airbag Coding - I think the second screenshot shows where you want to be, and then just clear the fault codes.
#4 d4nnyk
d4nnyk
  • 769 posts
Posted 14 September 2009 - 01:28 PM
DG
Well the fault was, I removed the airbag and then had to move the car, so moved it with out the airbag attached. It is now all fitted back. Have tried the fuse 8 trick, but that hasn't worked.
#5 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 14 September 2009 - 01:42 PM
Sounds like you need to run the diag on the code reader to find out what it is saying ;) and if need be reset DG
#6 FLD
Posted 14 September 2009 - 04:08 PM
Same with mine. Air bag out, move car so the light comes on. Reinstall the air-bag, clear the codes then reflash the squib code bit with the right variation...seatbelt tensioners and driver airbag (I think).
#7 d4nnyk
d4nnyk
  • 769 posts
Posted 16 September 2009 - 07:05 AM
Ok so i cleared the codes and reflashed the squib code. Checked the fault codes and all clear. Turned ignition off then one, airbag light still one.
Now with fault codes:
00052 - Control Unit (Squib Code) not Programmed Present
00053 - Squib Circuit Code Mismatch Present
00038 - Passenger Pretensioner Circuit Low Resistance Not present
00036 - Driver Pretensioner Circuit Low Resistance Not present
Have a f**ked it?? am I going to have to take it to vauxhall to get it sorted??? Also now the engine light stays on until I start the car, which handbook says that means a fault with the immobilizer, but there are no fault codes for the immobilizer when I checked.
#8 starlight
starlight
  • 1,790 posts
Posted 16 September 2009 - 08:02 AM
Try again going through the instructions and following for as if it is a new ecu... :unsure:
#9 d4nnyk
d4nnyk
  • 769 posts
Posted 16 September 2009 - 08:17 AM
Done that, still doesn't work, it is like the ECU isn't holding the programming. Think I need to take it in thumbsdown
#10 starlight
starlight
  • 1,790 posts
Posted 16 September 2009 - 08:53 AM
How many times was the ignition on with the airbag disconnected? A colleague of mine who works with airbag ECU software did mention to me that the ECU may be programmed to only be reset a finite number of times (in the case of Conti-Temec ones, not that these are fitted to the VX). :unsure: As per FLD, I did not have problems resetting the airbag ECU/light...
#11 d4nnyk
d4nnyk
  • 769 posts
Posted 16 September 2009 - 09:18 AM
Can you remember which programming option you used?? Driver Only or driver Only Without Pretensioner??
#12 starlight
starlight
  • 1,790 posts
Posted 16 September 2009 - 10:05 AM
Pretty sure it was
Front airbag Config - Driver only
Pretensioner Config - Driver & Passenger
All others - not in use
Then when confirmation of programming ok, cleared error codes
Edited by pjohn151, 16 September 2009 - 10:07 AM.
#13 jkm06
jkm06
  • 74 posts
  • Interests:spray painting car and repairing them both bodywork and mec. Goin to the gym and enjoy a good film
Posted 16 September 2009 - 05:38 PM
Pretty sure it was
hi have you manage to rest the air bag system. Just out of instrest what system are using to check the faults.? It's just i reset the system in my gf astra cabby as we had the seats out for a retrim and all i did was exacts the air bag ecu checked for faults and cleared them that was all.
#14 jkm06
jkm06
  • 74 posts
Posted 17 September 2009 - 07:11 PM
Pretty sure it was
did'nt uses either one. Just exacts the full airbag system checked the faults then cleared them. Can i ask whats the dia software you r using that maybe the probblem.?
#15 starlight
starlight
  • 1,790 posts
Posted 18 September 2009 - 08:37 AM
OP-COM (mentioned in the first post :rolleyes: )
#16 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 06 December 2009 - 05:34 PM
I am getting the following error messages and the airbag light is on... 00052 - Control Unit (Squib Code) not Programmed Present 00053 - Squib Circuit Code Mismatch Present 00038 - Passenger Pretensioner Circuit Low Resistance Not present 00036 - Driver Pretensioner Circuit Low Resistance Not present Also, after looking at the airbag pdf on the wiki site I don't get the drop down options (SAB8) as seen on page 2. It's starting to get annoying.
Edited by p4cks, 06 December 2009 - 06:23 PM.
#17 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 06 December 2009 - 06:43 PM
I've tried to clear the fault codes, and the airbag light goes out briefly but it goes straight back on. Same error codes. I also have never been given the option of the airbag coding SAB8 on my op-com program. Any ideas?
#18 d4nnyk
d4nnyk
  • 769 posts
Posted 07 December 2009 - 08:14 AM
The only way I managed to fixed mine, was to send my Airbag control unit off to a guy on ebay, he charged me £25 and he completely reset the EDU and reprogrammed it for me. I just reinstalled it and the light went out.
Everyone was telling me it was the squib at fault, but me logic was if you get the error code - ECU not programmed and mismatch something must be wrong with the airbag control unit
EBay Seller 3l3ctric33l
Hope this helps
#19 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 07 December 2009 - 07:30 PM
thumbsup I'll give that a try
#20 deaco
deaco
  • 17 posts
Posted 08 December 2009 - 04:42 PM
I have the same problem with my light on. Have just had Mike at Sports Car Services run a diagnostic and he is going to sort for me. Will let you know what he does.
