Standard Wheel/tyre Weight?
8 replies to this topic
#1 Fagan
Fagan
  • 264 posts
Posted 19 September 2009 - 05:38 PM
Whilst changing my engine mount today, I noticed how fcuking heavy the rear wheels are! This has got me seriously considering a change of wheels (most likely TD 1.2s). How much do standard wheels weigh as opposed to TDs? Is it worth the cost for the weight reduction acheived? Cheers
#2 Leon_1984
Leon_1984
  • 266 posts
Posted 19 September 2009 - 06:15 PM
it always will be, unsprung weight effects the handling lots. With my trackday car, I changed from the standard gti wheels to BBS Solitudes (again standard fit but only on special models) and they weighed a lot less and made a big difference to initial turn in
#3 Fagan
Fagan
  • 264 posts
Posted 19 September 2009 - 06:35 PM
I know that it will improve the performance all round but I what mean is, is the £900 odd that it will cost me justifiable over other things that could be done to the car for the same money.
#4 techieboy
Posted 19 September 2009 - 06:54 PM
If you're planning on keeping the car for any length of time then probably yes. Along with the unsprung weight savings, it opens up a whole world of different (and usually cheaper) tyre options before even getting on to the delights of semi-slicks.
#5 _JoE_
_JoE_
  • 81 posts
Posted 20 September 2009 - 08:06 AM
Standard Turbo (i think) Fronts - 9.8kg
Rears - 11.6kg
Team Dynamics Front - 7.3kg
Rears - 8.0kg
Speedlines Fronts - 11.0kg
Rears - 12.0kg
Speedlineaikes Front - 8.1kg
Rears - 10.0kg
Speedline Magnesiums Fronts - 6.70kg
Rear - 8.1kg
Compomotive MOs Front - 8.3kg
Rear - 10.1kg
Oz Superturismos Fronts - 7.1kg
Rears - 7.2kg
Speedline Turini Fronts - 8.4kg
Rears - 8.7kg
ATS DTC 17*7,5 J Fronts - 8,1-8,4 kg
17*9J Rears - 9,1-9,3 kg
Oz Superleggera Fronts - 6.9 kg
Rears - 8.3 kg
Various Wheel Weight Thread
The performance gain achieved by reducing the wheel mass can be quantified using a factor of six. This means that to achieve the same performance gain by reducing the body mass, it is necessary to remove six times the wheel weight saving.
Example A saving of 2Kg Per Wheel x 4 Wheels = Removing 48 Kg from the Bodywork.
What do you normally use your car for? Track or road?
joe
#6 Fagan
Fagan
  • 264 posts
Posted 20 September 2009 - 11:06 AM
Rears - 11.6kg
Rears - 8.0kg
Rears - 12.0kg
Rears - 10.0kg
Rear - 8.1kg
Rear - 10.1kg
Rears - 7.2kg
Rears - 8.7kg
Rears - 8.3 kg
joe
Thanks for the info mate. The car is mainly used for fast road use with the insentive to do trackdays at one point in the near future.
#7 Leon_1984
Leon_1984
  • 266 posts
Posted 20 September 2009 - 01:22 PM
wow didnt realise it worked like that ^^^ has to be worth it then imo. Plus im not keen on either NA or Turbo wheels
#8 Decky
Decky
  • 281 posts
Posted 20 September 2009 - 05:25 PM
that cannot be right can it? a saving of 2kg from each wheel is the same as 48kg from the body!? how would/does it work?
#9 spuk87
spuk87
    Ex-owner
  • 3,624 posts
Posted 20 September 2009 - 09:11 PM
I think it just means in purely handling terms, you would need to save 48kg from the main body of the car (sprung mass) to get the equivalent effect of saving 8k on the unsprung mass. Obviously that wouldn't increase acceleration or braking ability by the same degree.
