Stand 2 Pot Ap's Fitted On Rear
14 replies to this topic
#1 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 25 September 2009 - 07:58 PM
I'm just trying to guage interest. I have fabricated a alumium bracket that mounts the standard 2 pot AP onto the rear and replaces the brembo. However the bracket mounts off two of the hub bolts. The problem with this is that the hub carrier cast brembo style mounting has to be machined off. What this means is that the brembo can never be but back on and you will therefore have no handbrake. In my case I have a second pair of hub carriers and when the car needs to be mot'd I can swop the hub carriers and stick the brembo back on. In addition to this the rear brake lines will need to be changed and two longer hub bolts obtained. To much hassle I think for most but this is an option. I can post a pic of the fabricated bracket if anyone is interested.
#2 siztenboots
Posted 25 September 2009 - 08:01 PM
must be a better way to convert from axial to radial mount
#3 slindborg
Posted 25 September 2009 - 08:05 PM
http://www.elisepart....php?product=27
they used to do converted 2pot's for rear + HB use too...
#4 Arno
Arno
  • 1,238 posts
Posted 25 September 2009 - 08:17 PM
Those are for ali S1 rear uprights where the original knuckle-mounts can be unbolted from the uprights and these put in their place.
Cast-iron uprights like the VX and S2 Elise can't use this adapter.
Similar brackets area avilable to convert the mounting, but they only work with (much) bigger brake discs as they also space out the caliper a lot.
#5 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 25 September 2009 - 08:22 PM
Its just that with many replacing the front with 4 pots the original 2 pots are lying around doing nothing.
#6 SteveA
SteveA
  • 9,157 posts
Posted 27 September 2009 - 10:06 PM
Why not put them on the leading edge of the disc instead of the trailing, using the other two bolts to mount it. You can leave the brembo on just for the handbrake and plumb the hose into the other caliper. I'm sure someone on here has already done this. A black speedster IIRC
Edit - it was OGR
Edited by SteveA, 27 September 2009 - 10:08 PM.
#7 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 27 September 2009 - 10:28 PM
I believe danger7 has the two caliper option fitted, tho haven't seen him about for a while. Might be worth a pm.
#8 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 29 September 2009 - 04:45 PM
One of my aims is to loose unsprung weight. Those brembos are heavy.
#9 chris_uk
Posted 29 September 2009 - 04:50 PM
ive also done this.. but mine can be removed.
#10 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 29 September 2009 - 06:27 PM
Could do a similar thing but replace the brembo with a wilwood mechanical spot caliper, very small, very light and disgned for exactly this problem.
#11 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 30 September 2009 - 07:21 AM
Yes, thanks for the ideas.
#12 MMSB
MMSB
  • 178 posts
Posted 03 October 2009 - 01:12 PM
Doesn't having 2 calipers on the rear make it harder to keep the disks cool?
#13 chris_uk
Posted 03 October 2009 - 01:21 PM
no, because the smaller one is just used for the handbrake.
#14 MMSB
MMSB
  • 178 posts
Posted 03 October 2009 - 01:38 PM
Even so, I would think that when you release the handbrake the pads will still just about touch the disk even if applying no pressure, thus making cooling harder...
#15 chris_uk
Posted 03 October 2009 - 01:40 PM
well the rear discs are the same size as the front and putting the front calipers on the rear makes it basically identical to the front setup.. i very much doubt that cooling will be at all effected.
