Wishbone Lock Washers
22 replies to this topic
#1 M3KDJ
M3KDJ
  • 156 posts
Posted 10 October 2009 - 05:54 PM
I'm in the process of renewing suspension bushes/balljoints/etc etc....
On the bolt heads and nuts that bolt the wishbones to the tub there are rectangular lock washers that you have to bend over once the bolt is torqued - need to order some more as mine have seen better days.
Now for the problem. The EPC shows these washers as normal M10 x 20 washers, (Number 6 here) have they done away with these now and replaced them with normal washers and nylocks?
Cheers.
Kevin
#2 rsg
rsg
  • 3,306 posts
Posted 10 October 2009 - 06:12 PM
Cheers.
Kevin
They were fitted on mine, but I just used normal washers when I put it all back together
#3 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 10 October 2009 - 06:14 PM
Nylocks would be fine i would have thought
#4 M3KDJ
M3KDJ
  • 156 posts
Posted 10 October 2009 - 06:22 PM
Cheers guys - normal washers it is then!
#5 BRG_Pete
BRG_Pete
  • 285 posts
Posted 10 October 2009 - 06:25 PM
Good luck with the work. I officially finished my refresh this morning with a GEO at Back on Track. They checked over each corner to make sure the work that I had done was OK. Regarding those lock washers, I didn't put them back on the car opting for new nuts, bolts and washers instead.
#6 M3KDJ
M3KDJ
  • 156 posts
Posted 10 October 2009 - 06:29 PM
Thanks - 3 hours work today, all 4 rear wishbones off, balljoints and bushes pressed out. Front to do tomorrow then off to the powder coaters on monday!
Just need to do the cam chain & engine mounts now!
#7 nimonic
nimonic
  • 17 posts
Posted 10 October 2009 - 08:33 PM
I did the same job last winter, vauxhall weren't able to find the tab washer part no. I ended up getting the tab washers from Stratstone's the lotus dealer in Leicester. I'll try and find the part no for you tomorrow.
#8 techieboy
Posted 10 October 2009 - 09:23 PM
Tab Washer, upper pivot bolts SKU: B116D0031F
£1.59 each from Christopher Neil
#9 vocky
Posted 10 October 2009 - 09:42 PM
and the lower B116D0032F :unsure: just ordered 4 uppers and 2 lowers, cheers Techie thumbsup
#10 slindborg
Posted 10 October 2009 - 09:43 PM
or nordlocks! imho V dodgy not keeping to locking nuts/tabs/washers.
#11 BRG_Pete
BRG_Pete
  • 285 posts
Posted 11 October 2009 - 09:37 AM
hmmm... might have to order a set aswell. Thought it would be OK following the EPC but would feel happier with these back on I suppose.
Kevin: It is well worth the work, just got back from the first proper drive after the refurb and the car is a joy to drive. Nice and smooth over the bumps, steering feels a lot sharper and all in all it just feels better connected to the road. Could easily be the best mod so far.
I was considering Gaz shocks (currently on S2s) and an adjustable ARB, but it feels so good I won't be bothering (at least not in the near future...)
#12 techieboy
Posted 11 October 2009 - 09:40 AM
Makes a surprising difference doesn't it? My car had done 65000 miles when I did the refresh and felt like a brand new car when I'd finished.
#13 BRG_Pete
BRG_Pete
  • 285 posts
Posted 11 October 2009 - 09:52 AM
Yep, really happy with the way it turned out.
If I go back to modding the car i'm inclined to go for handling over power at the moment. Might even sell the set of Schrick Cams and Springs that have been sat in the cupboard for the last 10 months...
#14 Winstar
Winstar
  • 4,264 posts
Posted 11 October 2009 - 11:10 AM
or nordlocks!
:yeahthat: I used nordloc washers on mine 33p each for the zinc coated steel ones, you also only need normal nuts not nylocs so even cheaper.
#15 M3KDJ
M3KDJ
  • 156 posts
Posted 11 October 2009 - 05:07 PM
Cheers guys - just ordered them thumbsup
Cheers Pete - Glad it's going to be worth the effort - the front wishbones put up a bit of a fight today but I got there in the end :wacko:
I would have just changed the one bush that had gone but managed to get most of what I needed from work for a steal :)
#16 vocky
Posted 11 October 2009 - 07:02 PM
except there are 8 uppers :beat:
#17 JG
JG
  • 13,617 posts
Posted 08 March 2011 - 10:21 AM
...and 4 lowers.
#18 FLD
Posted 08 March 2011 - 10:26 AM
Doing mine too. Mine had nylocs, thread lock and locktab washers. I just ordered a set of locktabs from Chris Neils. Paul just found exactly what I needed and posted them to me. Top job. Then a bolt set from elise shop...and ....and....and... It gets expensive!
#19 JG
JG
  • 13,617 posts
Posted 08 March 2011 - 11:05 AM
the bolt set from elise shop is overpriced and not plated so it will look tatty in no time, i'm putting together a much better kit.
#20 FLD
Posted 08 March 2011 - 11:30 AM
The kit I have is plated. Fairly heavy plate but I agree its is overpriced.
