Throttle Bodies
Posted 20 October 2009 - 04:59 PM
Posted 20 October 2009 - 05:03 PM
Edited by rcvaughan, 20 October 2009 - 05:04 PM.
Posted 20 October 2009 - 05:05 PM
Posted 20 October 2009 - 05:06 PM
Thanks.
So where do I get the ITBs from?
Cheers
Webcon or TMS
(you just missed out on a second hand set from Lee
http://www.thorneymo...roducts_id=2717
Edited by rcvaughan, 20 October 2009 - 05:21 PM.
Posted 20 October 2009 - 05:12 PM
Posted 20 October 2009 - 06:56 PM
high performance cams, and even possibly a gas flowed head though... Vocky's the guy to talk to about this, but generally you'd go for stronger valve springs and balance shaft removal so you can make the most of the high RPM performance...
Posted 20 October 2009 - 09:24 PM
Posted 20 October 2009 - 09:34 PM
What are the intake temps like. I imagine not too bad what with the grills in the bonnet cover?
Never like the idea of open tb's, anybody running them in a sealed box with a cold air pipe to the side as normal?
Even in closed engine bays I've never seen high inlet temps on open TB's.
aside from Vocky and possibly Alanoooooooooo, the ITB results on the Z22 have been disappointing at best. OK they sound divine but since the engine has a long ass stroke its never going to be as potent as a 20XE on TB's
Posted 20 October 2009 - 10:02 PM
Vocky is.anybody running them in a sealed box with a cold air pipe to the side as normal?
Posted 21 October 2009 - 07:52 AM
So i have read, i assume playing with trumpet length hasn't altered the result much?
Posted 21 October 2009 - 08:01 AM
Posted 21 October 2009 - 08:07 AM
I extended mine by 45mm, changed the cams, upped the CR to 11:1 and raised the rev limit, that resulted in a 50 hp gainaside from Vocky and possibly Alanoooooooooo, the ITB results on the Z22 have been disappointing at best.
Posted 21 October 2009 - 09:00 AM
Aside from Vocky and possibly Alanoooooooooo, the ITB results on the Z22 have been disappointing at best. OK they sound divine but since the engine has a long ass stroke its never going to be as potent as a 20XE on TB's
I think if you're just after lots of power then forced induction is a far more efficient way to get power with these engines.
But the noise of ITBs... Oh my god
I still have to tune my cam + spark timings properly, but even so the car is at least as fast as before - but the induction roar gives you the most amazing feeling when going for it, which IMO would be worth it even if there was no performance improvement.
Posted 21 October 2009 - 09:14 AM
I do not have ITBs yet, because I don't like Webcon solution (even if very good, I always aim for pefect solutions...)
Btw, to be honnest, the 2.4 manifold is not flowing enough for my engine, I'm seeing some vaccum at max torque/hi RPM, these are quite a lot of HP lost...
markv said in a post that they are seeing same kind of issues (just not as bad) on other engines... so that's still a lot of HP to gain on the inlet side for almost everybody !
ITBs are the easiest solution to kill any restrictions on the inlet side, even if a perfectly engineered plenum might be best (except it will need hundreds of hours of engineering).
Oh, maybe I should quote a mail I got some days ago too
Sent: Monday, October 19, 2009 5:53 PM
To: alan@hardware.fr
Subject: RE: ATPower DTH throttle bodies for a GM/Vauxhall late Ecotec engine ?
Hi Alan,
Thanks very much for the enquiry. The information you sent me is very useful and is exactly what we need to begin to design a system. We currently have a lot of systems on design but we don't have the space to manufacture them at the moment. If we get around to making this system I will email you the information.
I’m sorry I can’t be more help at the moment.
Regards,
John.
ATPower shaftless direct to head ITBs might be coming one day...
Edited by alanoo, 21 October 2009 - 09:16 AM.
Posted 21 October 2009 - 09:28 AM
Posted 21 October 2009 - 11:03 AM
Posted 21 October 2009 - 07:44 PM
The problem with fitting ITB's to the Z22SE engine is that the inlet ports are designed to provide alot of turbulence at low revs so there is good incylinder mixing and torque at low revs, however this means that they become a restriction at high revs which is where the ITB make the real difference So you really need head work to make the conversion worthwhile.
A lot of people say it improves the driveability of the car but I wonder if that's more to do with the cable throttle and new ECU.
aside from the fact once the std ecu has learnt some gash values for transition from idle drive to moving with vigor, the driveability is one of the best I've experienced from an OEM ETB setup...
plus I dont think this 'flat spot' that people
Posted 21 October 2009 - 08:03 PM
'Winstar' post='947769' date='Oct 21 2009, 12:03 ']The problem with fitting ITB's to the Z22SE engine is that the inlet ports are designed to provide alot of
got itb's since over6 month and i find it very nice but it is a big tease
arrive on a round about last night and taking a junction of a motorway i had to floor it and enjoy......... when the power come you just don't stop and need to be good i need my licence the sound is just pure alcool in your brain just need more ponnies that's all
i do agree on doing mods to compliments them....just did the all exhaust and manifold and new cams and my head is on his way to be ported polished and machine with fews other mods and a good remap will reveal me what i have finally gain lol
on fact it is bloody expensive lol
Edited by crazyfrog, 21 October 2009 - 08:05 PM.
