Scrub Radius
9 replies to this topic
#1 kek700
kek700
  • 72 posts
Posted 25 October 2009 - 01:28 PM
Does any one know what the front scrub radius is meant to be in mm at the road surface, also is it positive, negitve or zero???
#2 Paulus H
Paulus H
  • 2,063 posts
Posted 26 October 2009 - 12:32 AM
Unusual question. You are taking me back to my days studying for my HND in Vehicle Design. I am afraid I don't have an answer but I would be very interested to know why you are asking this question....
#3 cnrandall
cnrandall
  • 943 posts
Posted 26 October 2009 - 09:40 AM
not the sort of info many people have kicking around... not even me! It's quite a large scrub radius though, small, highly inclined top wishbones and long bottom ones so lots of camber change....
#4 Muncher
Muncher
  • 4,494 posts
Posted 26 October 2009 - 09:59 AM
Simon at Cornering Force will have the data for 16" fronts but not the standard wheels.
#5 siztenboots
Posted 26 October 2009 - 10:04 AM
Lotus Elise Front suspension roll centre height 30mm travel 50mm bump / 60 mm rebound camber gain in bump 0.31 degrees per inch frequency 90cpm KPI 12.0 degrees Castor 4.25 degrees Trail 4mm Scrub radius 10.5mm Rear suspension roll centre height 75mm travel 50mm bump / 70 mm rebound camber gain in bump 0.45 degrees per inch frequency 98cpm
#6 Paulus H
Paulus H
  • 2,063 posts
Posted 27 October 2009 - 12:08 AM
Impressed!
#7 cnrandall
cnrandall
  • 943 posts
Posted 27 October 2009 - 09:11 AM
Me too!
#8 siztenboots
Posted 27 October 2009 - 09:27 AM
not sure if that is S1 with alloy uprights , but are all the relevant pickup points , arms the same
#9 kek700
kek700
  • 72 posts
Posted 27 October 2009 - 05:36 PM
thank you for the information...from the this i will assume positive scrub of 10.5mm
#10 sc-009
sc-009
  • 106 posts
Posted 28 October 2009 - 04:59 PM
Lotus Elise
Front suspension
frequency 90cpm
KPI 12.0 degrees
Castor 4.25 degrees
Trail 4mm
Scrub radius 10.5mm
Rear suspension
frequency 98cpm
I really must read that analysis document properly one day. Keep forgetting i have it, looks like a good read.
