Z20let Block/gearbox Bolt Holes.
11 replies to this topic
#1 Nev
Posted 27 November 2009 - 12:35 PM
What 'M' size are the bolt needed to hold my Z20LET iron block onto my new engine stand - they look like M10, but it would be nice to know for sure... In particular there are 2 meaty looking holes at the top of the block, where the F23 fits...
#2 techieboy
Posted 27 November 2009 - 12:39 PM
Assuming the turbo F23 gearbox casing is the same as the na F23 then I think they are M12 bolts for the gearbox casing to the block.
Edit: Yep, M12 according to TIS
Edited by techieboy, 27 November 2009 - 12:42 PM.
#3 slindborg
Posted 27 November 2009 - 12:40 PM
As its the XE bottom end, Last time I split one of those it was M12 too
#4 Nev
Posted 27 November 2009 - 12:41 PM
Thanks chaps... off to B&Q as its my nearest place to grab 4 of them now...
#5 Nev
Posted 27 November 2009 - 01:57 PM
Just returned, and the M12 bolts fit nicely, just need to borrow an engine hoist now for 30 mins...
#6 Nev
Posted 27 November 2009 - 09:36 PM
Managed without the engine hoist and lifted it up by hand with the girlfriend - thanks goodness we weight train !
#7 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 28 November 2009 - 09:36 AM
Haha, i'd like to see my lady try and pick something heavier than her hair straighteners up. Although she is on brolly duty today while i change some brake lines on the shed
#8 siztenboots
Posted 17 October 2010 - 09:25 AM
Did you bolt into the block threads or through to a nut as some of the block bolt holes stand proud of the facing I think a trip to Bnq is for today 12 x 130 or 150? http://www.diy.com/d...terGallery=true
Edited by siztenboots, 17 October 2010 - 09:31 AM.
#9 Nev
Posted 17 October 2010 - 05:33 PM
If I remember correctly, I used 4 bolts, 2 of which I had to use nuts behind and 2 that went into threads in the block. I think (75% likely to all be 12mm). Sorry to be so vague, but it was 8 months ago when I did this.
#10 siztenboots
Posted 17 October 2010 - 08:29 PM
No I think I understand as I have had to do the same to get enough clearance to the block and to the engine stand arms and main boss
#11 Winstar
Winstar
  • 4,264 posts
Posted 17 October 2010 - 08:40 PM
Just make sure they are a minimum of Grade 8.8 to take the torque
#12 jbudgie
jbudgie
  • 521 posts
Posted 18 October 2010 - 08:02 AM
Amazing :o
