Injector Flow Rates
9 replies to this topic
#1 rabidh
rabidh
  • 1,640 posts
Posted 02 December 2009 - 12:56 PM
I think I've got a dodgy injector in my 2.4L engine. It's an LE5 import from the US, so getting spares will be pricey. I wanted to try and find a source from inside the UK.
I found that it seems Mondeo St200 injectors have the same plug and look about the same (apart from colour):
http://cgi.ebay.co.u...=item19b81d1406
As far as I can tell from the net, these are 380cc/min (no idea what pressure), but there are 6 of these for a 200bhp, 2.5l - and I have to use 4 on a 200bhp 2.4l so my first guess would be that they are too small :(
Is there an on-line flow rate calculator (or table I can look my current injectors up in) anywhere, or does anyone have any tech specs on what the LE5 has? What is the flow rate of the standard 2.2 injectors? (and what pressure? I'm using the Z22SE fuel rail)
thanks,
#2 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 02 December 2009 - 01:12 PM
Calculator
Standard Z22se is 3.8 bar
Edited by NickB777, 02 December 2009 - 01:20 PM.
#3 rabidh
rabidh
  • 1,640 posts
Posted 02 December 2009 - 01:19 PM
Calculator
Awesome! Thanks, so I should be good for 328 cc/min @ 43.5 psi - but what pressure is the standard VX220 fuel rail?
#4 rsg
rsg
  • 3,306 posts
Posted 02 December 2009 - 01:27 PM
thanks,
When I had mine cleaned they were rated at 225cc/min at 3bar.
I've got some 2.0 SC LSJ Green injectors+harness spare if they help :unsure:
#5 siztenboots
Posted 02 December 2009 - 01:30 PM
also depends on the fuel rail pressure
#6 rabidh
rabidh
  • 1,640 posts
Posted 02 December 2009 - 01:33 PM
I have some of those too (but I'd have to gut my old engine's wiring harness to use them :( ) What does the harness consist of? You mean the whole old engine harness, or just something for the injectors?
I figured if I could just get some more injectors with the same fitting I wouldn't have to mess around with wiring adaptors. Even better if they had higher flow rate as I'm pushing 90% duty now I think.
Actually does anyone know about the impedance/how these injectors are meant to be driven? Currently I'm driving them as high imedance (i think) - basically just leaving the injector on all the time I want fuel (rather than a pulse to open, and then halving the duty cycle after that).
#7 rsg
rsg
  • 3,306 posts
Posted 02 December 2009 - 01:39 PM
The harness is just the 4x injector connectors back to a 5 pin single connector. Taken from an ebay listing for recon z22se injectors: Part number - Siemens Deka GM12565474 - Please ensure compatibility before purchase. Flow rate - c225cc/min at 3bar - Injectors will be given a final clean before dispatch. Resistance - c13.7 Ohms - High impedance.
#8 vocky
Posted 02 December 2009 - 02:50 PM
z22se has a 4 Bar fpr fitted as standard the 2.4 uses the same size injectors as the 2.2, just a different type my advice would be to get some z20let injectors and map your ecu to them :closedeyes:
#9 rabidh
rabidh
  • 1,640 posts
Posted 02 December 2009 - 03:16 PM
They don't actually seem to have the same connector :(
Z20LET
http://www.astraturb...injectornew.jpg
ST200/LE5 - EV-6 I think
http://www.cprracing.com/newinj.jpg
I actually quite like the idea of having 6 too so I could swap one out if there is an issue. Also if the greens really are 328, that makes 380cc@4 bar, which is basically perfect.
#10 vocky
Posted 02 December 2009 - 03:22 PM
I just pop along to the breakers and chop off a few plugs for whatever I require
