Vw Urban Fox Problems.
Posted 02 January 2010 - 10:29 AM
Posted 02 January 2010 - 10:43 AM
Posted 02 January 2010 - 10:54 AM
A lady friend of mine has a VW Urban Fox and is having a major problem with condensation on the inside of the front screen and today it was also frozen.
Does anyone on the forum have a family member or friend with this model ? if yes, do they get the same problem ?
Geoff.
Suggest:
1) Check for body waterleaks and subsequent damp carpets.
2) Is the car loosing coolant? If so check for heater hose connections or possible heater matrix leak.
3) When demisting make sure you are on 'fresh air intake', NOT recycling on the heater controls.
4) When demisting also run the Air Con (if fitted) with the heat control set to max. (The heater will overwhelm the cooling effect
but the air con will still act as a powerful de-humidifier )
HTH
Cf
Posted 02 January 2010 - 11:10 AM
Posted 03 January 2010 - 09:42 AM
Posted 03 January 2010 - 04:36 PM
Quick easy fix is to get a large bag of silica gel and leave it on the dash board at night.
Is there water leaking into the car anywhere? As there must be a reason for all the extra humidity
Cheaper alternative to silica gel is to use cat litter in a sock. Never tried it myself but is a well known technique for getting condensation out from MX5s!!
Best of luck...
Mike
Posted 04 January 2010 - 12:52 PM
Posted 04 January 2010 - 07:45 PM
Geoff.
i no it may sound silly but has she got the vents on the windscreen all the time? i sometimes have to re program volvo xc90 damper motors so they dont rest with the vents open on the windscreen when the car is turned off, if not then must have a water leak somewhere, melting snow on the floor? any coolant loss?
