Removing Heater Box Help Needed
Posted 01 February 2010 - 12:53 PM
Posted 01 February 2010 - 12:55 PM
I want to remove my heater box.
Do I have to remove my battery first?
Any other tips please...
Oh yes!
Posted 01 February 2010 - 12:56 PM
Posted 01 February 2010 - 01:05 PM
Posted 01 February 2010 - 01:09 PM
Once the Battery is out you can see the heater box, under the blue hose in the picture above.
Disconnect all the hoses and the control cable and the two (I think it's two) bolts that hold it in place and then slide the entire box over into the space the battery has left.
Once it's in this space it can be lifted out, although it is a right PITA as it only just fits through the space.
Posted 01 February 2010 - 01:21 PM
Posted 01 February 2010 - 01:37 PM
Edited by simsy, 01 February 2010 - 01:45 PM.
Posted 01 February 2010 - 01:48 PM
If broken they are not easily fixed. I just resoldered them together but had to use high temp solder and an iron at 500deg C to get them to join.
The main preoblem with the heater box is the p*ss poor way in which it is sealed. The picture below is of my Heater box after I sealed it with RTV Silicone sealant (In Grey).
These were the only mods I made to mine, car already had the Silicone hose mod seen in the previous picture I posted. The heater is now really good, heats up quickly and get's proper hot.
I took mine apart completely, drilling out all the rivots to seal it properly but I'm sure you can just go round the gap in the two halves with some sealant and it should do the job!
Posted 01 February 2010 - 02:02 PM
Posted 01 February 2010 - 02:08 PM
Posted 01 February 2010 - 02:20 PM
First time I've seen a picture of the blower control resistors
They're sh1t!!! I think if I ever get around to replacing them, I'll shall be putting something better in.
Re crap heater and everything seemingly good, well they are renowned for being crap. Maybe your thermostat is on its way out, this could give you crap heat.
Good luck with that!
I thought the same but they are a bastard awkward size. Can't remember what that size is now! but as we know "Search is your friend!"
Maplins couldn't help, I found something in RS but they were huge and wouldn't fit in the heater box, well they would but would seriouly restrict the flow.
Anything small enough is an horrendous price!
Wire coils are the cheapest option, as Lotus had clearly already sussed out so I just fixed what I had.
Posted 01 February 2010 - 02:30 PM
Posted 01 February 2010 - 03:06 PM
Edited by turbobob, 01 February 2010 - 03:09 PM.
Posted 01 February 2010 - 03:14 PM
Posted 01 February 2010 - 03:17 PM
Posted 01 February 2010 - 03:28 PM
Edited by simsy, 01 February 2010 - 04:00 PM.
Posted 01 February 2010 - 04:34 PM
to use a 10W W/W 1R resistor for fan position 2 (Maplin part code H1R) and a higher resistance 10W W/W 2.2R for the slowest, fan position 1 setting (Maplin part code: H2R2). Soldered directly in place of the original coils so that they'd hang into the fan box/housing and allow them to be cooled, just like the originals (as they are wire wound, they do get warm/hot, but they're ceramic, and won't catch fire!).
Posted 01 February 2010 - 04:57 PM
10W? I did a search earlier, and got the impression they were 50W (I have to admit I did think that seems a bit high).The SELOC fix for the early S2's that have the same heater box and resistor wire set up is:-
I can't see 1ohm 10W and 2 (or 2.2) ohm 10W resistors being that hard to get hold of.
