More Engine Options - 411bhp 9000rpm
10 replies to this topic
#1 siztenboots
Posted 03 February 2010 - 10:15 AM
currently thinking about the corsa vxr Z16LER with the m32 6 speed box , 411whp and 9000rpm
http://www.petropoul...d...&Itemid=121
some very good internals options from flatlander
to give you some idea about packaging
power steering and aircon pump come away from block, remove tensioner and swap damped crank pulley for an underdrive so you run a straight belt to the alternator
#2 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 03 February 2010 - 10:20 AM
Always said that the corsa 1.6T VXR engine would be great in the VX! thumbsup
#3 Code Monkey
Code Monkey
    forum whore
  • 2,425 posts
Posted 03 February 2010 - 01:05 PM
Got to be a decent weight gain on that option as well
#4 siztenboots
Posted 03 February 2010 - 01:34 PM
surprisingly not
#5 cnrandall
cnrandall
  • 943 posts
That's what I was thinking... Which block is that and does anyone know a weight?
#6 The Knobs
The Knobs
  • 3,481 posts
Posted 03 February 2010 - 03:08 PM
So how good will the new Westfield be ? I wonder if I should keep my old Striker and try one of these in it ? How much are these engines going for then and is there a rwd bellhousing available ?
#7 siztenboots
Posted 03 February 2010 - 03:54 PM
boggo standard GM europe would most likely fit.
not much weight over the rear wheels, so you will need to get used to looking sideways a lot
Edited by siztenboots, 03 February 2010 - 03:57 PM.
#8 markiii
markiii
  • 1,052 posts
Posted 03 February 2010 - 04:02 PM
christ thats a tiny engine
#9 dominik
dominik
  • 69 posts
Posted 03 February 2010 - 04:40 PM
Z20let 155kg 341,7pounds acording to Din 70020
Z16let/ler/leh 130,6kG 287,9pounds acording to Din 70020
Does anyone know the wheight of the Z20leh engine
The M32 gearbox seems to be heavier than the F23.
Edited by dominik, 03 February 2010 - 04:42 PM.
#10 siztenboots
Posted 03 February 2010 - 04:43 PM
i think a zlet + f23 is around 225kg
#11 vocky
Posted 03 February 2010 - 07:02 PM
I think the M32 weighs approx 4 Kg more than the F23
