Picture Of Lambda Sensor Plug-in From Engine
17 replies to this topic
#1 adlewar
adlewar
  • 137 posts
Posted 17 February 2010 - 08:58 AM
anyone got a picture/link to where the lambda sensor/s plug into, looking from above the engine.... i believe one of the sensors has a right plug in socket, and a wrong one...(below the coolant tank??) would be good to see both.... seen the 'useful thread' lambda bit, but still unsure..... i'm about as mechanical minded as a brick can swim....... chinky chinky
#2 adlewar
adlewar
  • 137 posts
Posted 17 February 2010 - 09:23 AM
sorted now guys, mods can delete this for me, i dunno how to......
#3 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 17 February 2010 - 09:59 AM
Photo would still be handy though if anyone has one?
#4 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 12:01 AM
:yeahthat: Bump This would be useful for me if anyone has one? Richard
#5 The Batman
Posted 27 February 2010 - 12:02 AM
im a bit confused! what do you actually wnat a picture off? where the lambda sensors plug into or ???
#6 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 12:14 AM
Yes, the connectors which the lambda sensors plug into.
Actually just the post cat sensor connector as the pre-cat one is shown in the useful thread collection.
I'm checking the connectors as per duncans advice on sorting my eml. Theres a connector in the pax side rear corner below the coolant tank which doesnt have anything plugged into it, I'm wondering if its the rear lambda sensor connector....
#7 The Batman
Posted 27 February 2010 - 12:16 AM
can get you the pictures tomorrow, if no one has posted by the time i wake up and get my act together :lol:
#8 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 12:25 AM
Cheers Joe chinky chinky
#9 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 12:32 AM
This is the empty connector in question....
#10 vocky
Posted 27 February 2010 - 08:29 AM
the post cat lambda sensor plug is just to the right of that spare plug thumbsup I have no idea what the spare plug is for :wacko:
#11 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 02:09 PM
Thanks vocky......the plot thickens
#12 The Batman
Posted 27 February 2010 - 02:12 PM
is the plug to the right? if not, then it would appear you have 2 of the same connectors thumbsup
#13 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 03:31 PM
There are two connectors the same, but they are going different places
The "large wiring bundle" goes forward under the engine mount bracket and disappears - this is the one with the spare connector
If I'm correct, the lambda sensor connector goes onto the wiring which goes to the ECU, which is also the same wire the pre-cat sensor is connected to. Is this right?
Anyone able to comment?
#14 The Batman
Posted 27 February 2010 - 03:40 PM
yh that looks wired up correctly to me... on the pre cat lambda sensor where is that going to?
#15 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 03:56 PM
Seems right to me....
#16 vocky
Posted 27 February 2010 - 04:05 PM
they are connected correctly, the two lambda sensors connect directly to the ecu, they share the same +12v feed and heater feeds but obviously use seperate cables for the output signal
#17 The Batman
Posted 27 February 2010 - 04:07 PM
so whats the random connector for? spare lambda sensor?
#18 zimmer
zimmer
  • 573 posts
Posted 27 February 2010 - 04:28 PM
Would be interested to know if anyone else has a "random connector" but fairly sure it's not causing my problems. Time to get the bottom off the car again... Thanks for your help guys
