Blow Off Dump Valve
13 replies to this topic
#1 Nath
Nath
  • 591 posts
Posted 18 February 2010 - 01:40 PM
afternoon people, just wanted to know if any of you guys, have one, or used one ect and your thoughts? does anyone have a video they could post with the sound of a blow off valve? nath
#2 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 18 February 2010 - 01:42 PM
i have one for sale if you interested
#3 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 18 February 2010 - 01:44 PM
Retain the oe recir if your going to use it - other option is to block the oe recirc but you need to mave the larger d/v a true recirc
#4 Nath
Nath
  • 591 posts
Posted 18 February 2010 - 03:10 PM
[quote name='Duncan VXR' date='18 February 2010 - 01:44 PM' timestamp='1266500680' post='999084']
Retain the oe recir if your going to use it - other option is to block the oe recirc but you need to mave the larger d/v a true recirc[/u]
come again???
duncan, im new to the "turbo" world. so im still learning :blush:
Edited by Nath, 18 February 2010 - 03:10 PM.
#5 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 18 February 2010 - 04:04 PM
There is a thread that someone put up for fitting an external larger dv to help combat the chatter issue we get with higher boost running cars. Because the car has a recir dv (put the unused compressed air back into the intake) the ecu knows this and adjusts the fueling to suit. By blocking this off and just having a dv that vents to the outside workld you can have the mixture a bit off between gear changes - prob not a massive issue but still not ideal. I have been running my external (larger than oe one on turbo) for a long time with no problems at all but do vent back in to my hard pipe before turbo. In fact the 1st :P So if you just want noise you need to run the oe one and whatever ext dv you want and plum into fpr. Hope this helps :) DG
#6 Nath
Nath
  • 591 posts
Posted 18 February 2010 - 04:26 PM
so the vx has a recir valve and a d/v??? :tumble: i get what your saying more now lol i thought it was a fact of plug -in-play :blush:
#7 P11 COV
P11 COV
  • 7,686 posts
Posted 19 February 2010 - 08:30 AM
No the VX has a recirc valve instead of a dump valve.
#8 Nath
Nath
  • 591 posts
Posted 19 February 2010 - 11:20 AM
No the VX has a recirc valve instead of a dump valve. [/quote] yeh i thought that! so if i wanted to use a d/v, i need to blank off the recirc valve, and make sure i get a twin piston d/v!
#9 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 19 February 2010 - 11:28 AM
[quote name='Nath' date='19 February 2010 - 11:20 AM' timestamp='1266578442' post='999453']
[/quote]
yeh i thought that!
[/quote]
Recirc is a d/v and in the case of the vx is attached to the turbo itself. (recirc vents the air back into the inlet system rather than the outside worldlike the d/v you are talking about)
As stated if you blank the oe recirc d/v you want the new ext d/v to be a recirc.
DG
#10 techieboy
Posted 19 February 2010 - 11:31 AM
Leave the chav valves to the ricers. thumbsup And the wannabees
Edited by techieboy, 19 February 2010 - 11:34 AM.
#11 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 February 2010 - 11:54 AM
And the wannabees
:yeahthat::yeahthat:
plenty of them where i live :( but when they ear those itb's of mine they better p*ss off B)
#12 Nath
Nath
  • 591 posts
Posted 19 February 2010 - 12:40 PM
please................. im NO chav!!! i thought the idea of a d/v was to eliminate lag between gear changes! that fake d/v sounds s**T!
#13 TankRizzo
TankRizzo
  • 475 posts
Posted 19 February 2010 - 02:15 PM
The dump valve can help avoid turbo stall on lift-off, but your OE recirc DV already does this job. Hence if you add the to-atmosphere DV to the system, all you'll gain is the fizzy pop noise.
#14 malcz
malcz
  • 404 posts
Posted 19 February 2010 - 04:09 PM
PM
