Rev Counter / Speedo Feeds
Posted 11 March 2010 - 08:22 PM
Posted 11 March 2010 - 08:54 PM
Posted 11 March 2010 - 09:13 PM
pulsed, for both
Perfect. Thats exactly what I wanted to hear. Thanks.
Posted 11 March 2010 - 09:22 PM
Posted 11 March 2010 - 09:29 PM
isn't the feed via the NSR hub, ABS, ECU, then finally to Stack.
Yeah it is. My concern was that if I tapped into the signal wire and it was an increasing current system then the current would be split and the instruments wouldn't read correctly. A pulsed system wouldn't suffer this. It should therefore be possible to just tap off the feed to the stack.
Posted 11 March 2010 - 09:52 PM
Posted 12 March 2010 - 08:16 AM
speed comes directly from the ABS ECU
rpm comes from the engine ECU, 2 pulses by rev
is that right? I thought the speed was adjusted by the ECU to overread as what I can see on the stack and what I can read from the OBDII are quite different. Also in the ECU I can see the traction control functions and switch , but not active , also cruise control functions.
Posted 12 March 2010 - 08:54 AM
Posted 12 March 2010 - 10:29 AM
Posted 12 March 2010 - 07:31 PM
Posted 12 March 2010 - 07:56 PM
The rev counter wire is pulsed and I spliced it to run a separate shift light and both shift light and rev counter work fine.
Thats the sort of thing I'm up too. Dont suppose you know what colour wire the rev counter feed is and what colour the speedo feed is do you?
Posted 12 March 2010 - 08:23 PM
Posted 12 March 2010 - 08:36 PM
Quick butt in on wiring. Nice to see a nice colourful loom. Spent the last few days sorting out a few wiring faults on a BV206. All the feeds are Red and earths Blue, only 2 colours on the vehicle. A little tricky trying to follow a wire haha
I know of somebody who rewired his Ford Cortina completely with a job lot of black wire he got.
He was fooked when it didn't work, had to scrap the car in the end...
Without taking the dash off I can't tell you for sure what colour the wire was, but I remember I got the info off this site.
Posted 13 March 2010 - 07:23 AM
Posted 13 March 2010 - 11:39 AM
Perfect, thanks. Looking forward to getting modding. Shame its so damn cold out there today. Looks like I'll be in the shed with the 'zorst.CLICK
If I'm reading that correctly it's the violet / pink wire going to H1.24 for the tach signal and the brown / blue wire going to H1.25 for the speedothumbsup
Posted 03 April 2019 - 11:14 AM
Posted 03 April 2019 - 11:33 AM
Hi Im looking to connect a BNC connector to let the judges check my maximum RPM on the engine, I’m racing a speedster Turbo and this is new for the season so really need some help Could this be the way to go, taping into the tacho feed?
do you want the wiring diagrams , I can email them over
Posted 21 April 2019 - 03:45 PM
Posted 21 April 2019 - 03:46 PM
