Charge Cooler Bleeding
Started by
rasputin
, Mar 13 2010 02:45 PM
6 replies to this topic
Posted 13 March 2010 - 02:45 PM
iam sure ive got air in my system and its not
runninig correctly.whats the best way to purge all the air
also how much coolant should i have in the tank?
ok just had another look and ive defo got air in
the top of the pipe just before the pump but i cant
get it out.
also what temps should i be getting< ive just got a scangauge
so i can have a look.
tah!
Posted 13 March 2010 - 04:27 PM
Re temperatures see my thread here:
http://www.vx220.org..._1
Be interested to see what you are getting.
Edited by P11 COV, 13 March 2010 - 04:28 PM.
Posted 13 March 2010 - 04:51 PM
pressurise the system by putting mouth on cap and blowing making sure no air is escaping
i also have fitted a bleed nipple next to my water pump
Posted 13 March 2010 - 05:40 PM
good job coolant aint poisonous !pressurise the system by putting mouth on cap and blowing making sure no air is escaping
lol
Posted 13 March 2010 - 05:43 PM
lol! a little never hurt anyone
Posted 13 March 2010 - 06:09 PM
Take cap off header tank, jack back of the car up sa high as you dare (watch the front). Give the pipes a squeeze if you can to move the air.
Posted 13 March 2010 - 09:37 PM
Without a doubt the best way I have found is, fill the c/c header tank with distilled water and 'wetter wetter'.
Idealy have another person at the ready to top up c/c header tank.
Connect a wet vac to the header tank return pipe and turn on.
Not only does it do it very quickly it removes all air from system.
Hope this helps, good luck.....
