Edited by leevx2.2, 15 March 2010 - 04:27 PM.
Posted 15 March 2010 - 04:27 PM
Posted 15 March 2010 - 04:55 PM
Posted 15 March 2010 - 07:11 PM
My middle tray is in the garage it has been for about 2 years havnt got around to puting it back onAs you'll be such an expert at middle tray removal, you can come round to mine and fit a new high pressure fuel line from the pump to the filter, if you want? It's taken me 3 days to get the feckin convoluted plastic pipes between the in-tank canister and the fuel pump fitted.
Edited by leevx2.2, 15 March 2010 - 07:12 PM.
Posted 15 March 2010 - 07:47 PM
Posted 15 March 2010 - 07:54 PM
At least it's only the one to the filter!My replacement cannister has all connections present and correct, so I need to replace the high pressure fuel line between the pump and the filter. And that is shaping up to be a pain in the proverbial.
Posted 15 March 2010 - 08:38 PM
Matt your car will be 100% new soon you must of replaced every mechanical thing on it.The high pressure outlet on my original pump got broken when the ProAlloy tank got fitted. So, there was a bit of a bodged repair involving cutting off the quick fit connector on the fuel line and adding some fuel hose in it's place (which caused a big fuel leak when the originally fitted hose kinked). My replacement cannister has all connections present and correct, so I need to replace the high pressure fuel line between the pump and the filter. And that is shaping up to be a pain in the proverbial.
Posted 15 March 2010 - 08:56 PM
Got to replace the flucking paintwork as well now. Finally removed all of last years Le Mans crap and it's pulled some lacquer off in a couple of places. Most noticeably a big patch on the front clam above the V.Matt your car will be 100% new soon you must of replaced every mechanical thing on it.
And i thought i was doing well but i have got allot of catching up to do with you
Posted 17 March 2010 - 11:17 PM
Posted 17 March 2010 - 11:22 PM
Posted 17 March 2010 - 11:36 PM
You're asking me why? The vinyl was fine until you came around with Joe and started peeling bits off.why did you remove it i was getting slowly used to it
Posted 17 March 2010 - 11:52 PM
mine you it did look like a aquamarine army car
It was looking a bit tatty, especially the lighter blue vinyl and I was bored with shredding my hands cutting holes in the car for the fuel pump. So one thing led to another......
Posted 22 March 2010 - 11:49 AM
Edited by Mangham54, 22 March 2010 - 11:50 AM.
Posted 22 March 2010 - 12:40 PM
Yeah all good it was my handbrake your problem sounds the same i loosend of my cable and allLee did adjusting the handbrake solve the problem?
Also when you said that the rear wheels were binding, was this all the time and/or did it get worse when in use (if you did drive it) - ie the friction from rubbing making them bind more?
Explaination, why I ask below(and apologies for the repetition of this question in several place- I hope that this will be the last) :
I changed all the discs and pads on mine at the weekend and the rear wheels spin relatively freely when cold, but after 5mins of driving they are much more difficult to turn... Plus when trying sping them as though reversing it is much more difficult to do. However once the pads and discs have cooled they spin relatively freely again (not quite as freely as the front wheels), but the pads are definitely still in contact with the discs. When feeling the handbrake cable, where it attaches to the caliper) there is little, if any, play even when the handbrake is loose.
Unfortunately because of this the car is still in Newcastle, whilst I am back in West Yorks for work this week, so any measurements of whether there is the required 76mm distance when the handbrake is off cannot be checked until Saturday now. The discs were ridiculously well worn (probably at or around the min thickness, with pads that were aproximately 8-10k miles old - with no anti-rattle pad in them) so the increase in size was probably quite considerable (also pulling the handbrake up before pumping brakes probably didn't help!) so am thinking this could be the issue....
Any help or suggestions will be greatly recieved..... I am now off to search for a local MV training course as my tinkering without actual study is starting to become an iritation for me (and possibly for a few on here as well)
Posted 22 March 2010 - 05:33 PM
Edited by Mangham54, 22 March 2010 - 06:23 PM.
