Anyone know if it has one & if so where it is? VXT not starting & I can't hear the fuel pump priming, fuel cut off is ok
Am I going mad or did there use to be a Technical section???!!!
I had a similar issue, changed the yellow relay in the boot which is found on the rear passenger arch under the plastic cover. Cheapest place was lotus for the new relay, around £20 posted.
Thanks guys - after f**king about for over an hour it started without me doing anything then wouldn't start again.
I pressed & held the keyfob until the light went out on the dash & it fired up - seems ok now, is that a reset does anyone know??
