Airbag Squib
#21
Posted 10 November 2010 - 10:32 AM
#22
Posted 10 November 2010 - 11:57 AM
#23
Posted 10 November 2010 - 05:56 PM
#25
Posted 10 November 2010 - 07:24 PM
#26
Posted 11 November 2010 - 08:26 AM
(Rushed around getting my airbag light fixed for the MOT wish I hadn't bothered now)
Edited by d4nnyk, 11 November 2010 - 08:27 AM.
#27
Posted 29 May 2012 - 11:13 PM
Had the airbag warning light on for a while now and finally got around to ordering an OP-COM which has arrived today. Plugged it in and got the following: 00031 - Driver Airbag Squib Circuit High Resistance Present.
Did you get your error sorted in the end Yaaan?
Just been putting my car back together for an MOT tomorrow and I've got the same error. Suspect my heater vomiting clouds of coolant at the airbag ecu a few weeks back has probably upset it.
OP-COM won't clear it, nor will it let me reprogramme the car as a non-airbag equipped car. Did you end up sending the ecu away to be re-flashed?
#28
Posted 30 May 2012 - 07:15 AM
I'd forgotten all about this!
I bought a squib off P4cks at the time but never got around to generating the necessary level of enthusiasm/motivation to get around to changing it. Then I took the car to MMG for some work and when I got it back the light was out so assume Liam had reset it. However, since fitting my ITBs the light is back on so need to look at this again. I've yet to check if the op-com will still talk to it although it should do.
I don't want to go through the hassle of sending the ecu away whilst I'm home but my MOT is due soon (forget when) so may have to see if I can sort this out when I get back in a couple of weeks. If you manage to find a solution let me know as I'll be on the case with this mid June.
Sorry I can't be more help.
#29
Posted 30 May 2012 - 07:32 AM
Anybody else out there with OP-COM than can do a quick scan of the airbag system on their car to see if the following log looks believable?
OP-COM 100219a - PC based diagnostic tool
Date and time>,29/05/2012. 22:3148
Workshop information:
hkj
Selected model>,2002 (2),Speedster/VX220,Body,Airbag
Control Unit:
KW82 protocol initialized.
ECU ID= 00,A116M6000,0007394,442947,0601,
Measuring blocks information:
System Voltage,6.95 V
System Voltage Status,Okay
Airbag Configuration,
Pretensioner Configuration,
Driver Airbag Squib Circuit Resistance,5.36 Ohm
Passenger Airbag Squib Circuit Resistance,0.00 Ohm
Driver Pretensioner Circuit Resistance,2.17 Ohm
Passenger Pretensioner Circuit Resistance,2.23 Ohm
Driver Side Airbag Squib Circuit Resistance,0.00 Ohm
Driver SAS Message Status (Side Airbag Sensor),Interrupted
Passenger Side Airbag Squib Circuit Resistance,0.00 Ohm
Passenger SAS Message Status (Side Airbag Sensor),Interrupted
Reset Passenger Side Airbag After Activation (DTC69),Inactive
Reset Driver Side Airbag After Activation (DTC68),Inactive
Reset Pretensioning Devices After Activation (DTC67),Inactive
Driver SAS Initialisation Status (Side Airbag Sensor),Okay
Driver SAS Communication Error (Side Airbag Sensor),None
Passenger SAS Initialisation Status (Side Airbag Sensor),Okay
Passenger SAS Communication Error (Side Airbag Sensor),None
DTC set since,300
