Delete Kit For Balance Shaft On N/a
5 replies to this topic
#1 jkm06
jkm06
  • 74 posts
  • Interests:spray painting car and repairing them both bodywork and mec. Goin to the gym and enjoy a good film
Posted 02 April 2010 - 04:08 PM
Does ne one know where i can buy a delete kit for the balance shafts on the N/A. Or if they is a diy way of removing them thanks j
#2 2-20
2-20
  • 1,317 posts
Posted 02 April 2010 - 05:37 PM
Level zero motorsport make a kit of bushes to be installed in the existing bushes. They block the oil ways. The shafts are stock shafts cut in a lathe.There is a core charge because you have to send back your stock shafts
LZM delete kit
It's not reversible.
You can also push (by 7.5 mm) the existing bushes to block the oil ways and cut your own shafts
Or buy neutral shafts from GM (but they are heavy and not cheap) or from ZZ performance (cheaper and lighter)
The neutral shafts is a reversible modification.
ZZ Performance
Edited by 2-20, 02 April 2010 - 05:51 PM.
#3 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 02 April 2010 - 05:48 PM
Worth talking to Vocky on here he's the Imnotworthy on these sort of things
#4 techieboy
Posted 02 April 2010 - 06:01 PM
No need to buy anything. Your existing balance shafts can be cut down to turn them into basically just idler wheels. Then with the careful application of a hammer on a socket attached to an extension bar, the bearings inside the block can be knocked the few mm's further into the block to block the oilway. It's an engine out job whatever. Pretty sure Vocky has done a guide on the Z22SE site.
#5 jkm06
jkm06
  • 74 posts
Posted 02 April 2010 - 06:12 PM
thanks for the info will defo b looking into it. that lookin for ways of turning engine up and saving some weight at same time. think it looking like some piper cams,balance shafts removed, 4-2-1 exhaust manifold with sports cat, flowed head with some valve work and lighten flywheel. company near me says £35+vat to lighten flywheel. ne ideas on waht cluches would be good for it. Its had remap at tms last year but thinking after this work will need another one. but not to sure where to go as tms is way down south frm me. And dnt think i can con gf to go bk to thrope park again haha
#6 john_s
john_s
  • 1,801 posts
Posted 02 April 2010 - 08:50 PM
I've got a lightened flywheel. AFAIK it's just got a standard clutch.
