Changing Front And Rear Pads
23 replies to this topic
#1 Kieran B
Kieran B
  • 1,101 posts
Posted 07 April 2010 - 05:57 PM
i got some new pads.. and im sure there will be a guide about some where.. i just cant find it anywhere. searched on here and google, but no joy.. if any one has some info to send my way, it will help a lot.!! thanks, K :blush:
#2 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 07 April 2010 - 06:03 PM
Not a hard job at all, and in fact easier than most other cars on the front. If you get really stuck, I can do them for some beer tokens. Will have to trek over to Essex though!
#3 The Batman
Posted 07 April 2010 - 06:04 PM
bring them to the bedford meet :lol:
#4 chris_uk
Posted 07 April 2010 - 06:09 PM
quick guide.. no pics Front : 1. wheel off 2. inset small drift (i use a small allen key) into the retaining pin hole (in the caliper) to push it out 3. take metal brace off (dont loose it) 4. take top bolt out of caliper 5. loosen bottom bolt 6. pivot the caliper down 7. both pads should be able to slip out 8. reverse order to put back in Rears : 1. wheel off 2. undo handbrake 3. take out retaining clip 4. pads should come out 5. use a pair of long nose pliers and insert then into the 2 holes on the piston and turn clockwise while pushing 6. reverse order to replace now i cant remember if you can get the pads out without removing the disc or not.. but you can try it, if you need to you can undo the caliper and pivot it like the front one, i think you need a 17mm socket on the top bolt.
#5 Kieran B
Kieran B
  • 1,101 posts
Posted 07 April 2010 - 06:53 PM
thanks guys! :grouphug: Joe, was that an offer? are we gonna jack the car up in teh car park LOL thumbsup
#6 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 07 April 2010 - 06:59 PM
Front :
1. wheel off
Rears :
1. wheel off
2. undo handbrake
10/10 and in the end removed the all caliper it was more easy to remove the pads
#7 Arno
Arno
  • 1,238 posts
Posted 07 April 2010 - 07:20 PM
Front :
Huh?? :huh:
Front caliper does not pivot??
Front pads are simply:
- pull R clips from rear of locking pins
- push pins to the outside and remove
- catch anti-rattle plate as it jumps out
- pull pads out
- use brake-cleaner liberally to clean piston surface and groove before:
- push pistons back with hands/thumbs
- clean up surfaces
- fit new pads
- fit lower locking pin
- fit anti rattle plate
- fit top pin
- refit R-clips in pins to stop them moving
Done...
Oh.. And on the back I find it much easier to tap out the locking pin, drive the outer pad towards the hub and down until it drops out. Then remove the brake disc and you can access the inner pad, piston, etc.
No need to mess around with the handbrake cable, bolts, etc. etc.
Edited by Arno, 07 April 2010 - 07:22 PM.
#8 chris_uk
Posted 07 April 2010 - 07:25 PM
my bad, i wasnt really thinking when i wrote that, but it was just basic..
#9 slindborg
Posted 07 April 2010 - 07:26 PM
Front :
1. wheel off
Rears :
1. wheel off
2. undo handbrake
other way round chap. well half of it lol
#10 chris_uk
Posted 07 April 2010 - 07:29 PM
its hard to remember having the front calipers on the back with standard calipers and 4pots on the front, i was getting confused which was which lol
#11 Winstar
Winstar
  • 4,264 posts
Posted 08 April 2010 - 08:34 AM
front brakes pdf guide
The original threads along with alot of other very useful ones seem to have dissapeared in the last move but the link for the front is above. I'll need to find the rear
edit and the rear rear brakes pdf guide
Edited by Winstar, 08 April 2010 - 08:43 AM.
#12 Whiteboy
Whiteboy
  • 6,950 posts
Posted 08 April 2010 - 08:39 AM
Yes they seemed to have lost loads of stuff including clam removal / bleeding the brakes. rant
#13 Kieran B
Kieran B
  • 1,101 posts
Posted 11 April 2010 - 06:56 PM
cheers! thats really helpful. how importnat is it to bleed the breaks after?
#14 slindborg
Posted 11 April 2010 - 08:35 PM
Just doing pads? then no need to bleed the brakes. just pump the pedal before driving otherwise you will overshoot the first junction :lol:
#15 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 12 April 2010 - 12:07 PM
I'll do em for you Kieron.
#16 DarrylB
DarrylB
  • 1,629 posts
Posted 12 April 2010 - 12:33 PM
Kieran, I'm up the road from you, just outside uxbridge! I'm not free until Sunday, so if you can hold out until then I can happily pop over and we can sort the brakes out.
#17 JEFF from Wales
JEFF from Wales
  • 4 posts
  • Interests:music,motoring,walking,photography,reading,diy.
Posted 14 August 2010 - 09:11 PM
To VX220.ORG and Scary Internerd and all others please forgive me for printing out the pdf files regarding brake pad change out front and rear for my VX220 T ,I am broke after having Baylis of Cheltenham fitted radiator clutch flywheel engine mounts and cooler reservoir,I am old Haynes manual user (Yes that old)but find doing the work that I usaed to do (30 years ago)on older cars ,clutch,head grind,CV joints etc is now a lot slower.Thanks to all from a silent member.
#18 euphoria
euphoria
  • 276 posts
Posted 19 August 2010 - 01:27 PM
Imnotworthy Thanks for the PDF files, going to change mine at the weekend i hope! (Weather permitting!)
#19 furtive
furtive
  • 1,134 posts
Posted 25 September 2020 - 08:14 AM
Looking at the guide for replacing the rear brake pads, do I need to release the handbrake before I start?
#20 smiley
Posted 25 September 2020 - 09:57 AM
Not Always.
If your disks do not have a lip, and the disk is standard size, you can:
1. Remove the retainer pin and spring.
2. Take out the pad on the outside by sliding.
3. Remove the disk retainer screw, and slide the disk towards the outside.
4. Remove the pad on the inside.
5. Remove the disk.
6. Rewind the caliper piston.
Adding new is the reverse order of above.
No need for caliper tilting, nor handbrake removal.
Edited by smiley, 25 September 2020 - 10:01 AM.
