What Type Of Connector....
6 replies to this topic
#1 Dave
Dave
  • 3,679 posts
Posted 26 April 2004 - 08:46 AM
I found some software (free) on the net to read the data from the ODB (?) port.. gives a reading of various things like how much throttle your using etc. It can be loaded onto a PDA and gives a live display of the above. But how to connect it?? Does the connection under the dash have a technical name? ++++++++++++++++++++++++++++++++++++ Alternativly, which might be easier; does anyone know of any software that can be loaded onto a laptop that would do the same. Again connecting to thingy under the dash may be a problem... any idears?? I'm not sure why I want to do this but it did sound interesting... Dave
#2 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 26 April 2004 - 08:50 AM
Its called an OBDII port. Working with a company at the moment for oen of the instrument guages but last two versions didn't work.
#3 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 26 April 2004 - 08:55 AM
Delta dash (develpoed by ECUTek I think) was very common on Subarus. Not sure if it could be addopted for the VX, but it does use the OBD port and if you know a bit about engine management you can remap your car yourself
#4 Marco Polo
Marco Polo
  • 268 posts
  • Interests:Cars and tracks :-)
    Roller skating in Paris
    Diving
    Wife and kids
Posted 26 April 2004 - 09:02 AM
There : Digimoto OBDII Vehicle Diagnostic Solutions : www.digimoto.com ScanTools.net - Inexpensive OBD-II scan tools : www.scantool.net B)
#5 Ratspants
Ratspants
  • 2,739 posts
Posted 26 April 2004 - 09:15 AM
I like the idea of the OBD guages, but I'd be thinking of the Defi-Link gear :)
I suspect the real trick is finding a way to mount them so that they are easily visible. A DIN sized thingy to fit in the radio hole would need to have bits of it angled towards you? Could they be fitted on the dash without be too obtrusive?
Ben
Edited by Ratspants, 26 April 2004 - 09:18 AM.
#6 Duncan
Duncan
  • 780 posts
Posted 26 April 2004 - 09:33 AM
Yup. OBDII. The biggest problem you'll have is that you'll need some level shifting and opto-isolation to convert between the K-Line data bus on the car and RS232 on the PDA / Laptop. Be aware that there are several different flavours of the K-Line bus, which is probably why Thorney is having issues.
#7 Dave
Dave
  • 3,679 posts
Posted 26 April 2004 - 11:23 AM
Right thats decided......leave it alone.... lets Thorny works his wonders on it. Thanks Dave **I was hoping I could just go out and buy a lead to connect to PDA + car**
