Heater Stuck On Hot!
5 replies to this topic
#1 Mixey
Mixey
  • 32 posts
Posted 10 April 2010 - 09:24 PM
My temp control switch is stucK on hot. The dial itself suck all the way to hot. Has anyone else had this problem? How can it be sorted....? Mike
#2 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 10 April 2010 - 09:29 PM
Open the bonnet and locate the cable on the heater box, try and manualy move the arm / link to shut off the valve and give it a soaking in wd 40 keep working it on / off or open / closed until it frees off chinky chinky
#3 Mixey
Mixey
  • 32 posts
Posted 10 April 2010 - 09:31 PM
sounds easy enough. will give that a bash. Thanks
#4 jaylin
jaylin
  • 279 posts
Posted 10 April 2010 - 09:35 PM
Remove heater cable from heater box, then test if "dial" is free. Suspect it will be, if so fault with heater box/hot/cold flap. Heater box will need removing to fix. May as well do the heater box mod upgrades while its out, plenty on here if you care to search... chinky chinky
#5 Whiteboy
Whiteboy
  • 6,950 posts
Posted 11 April 2010 - 06:51 AM
For a quick fix, where the cable meets the heater box, spray some wd40 down the hole and this will hopefully free the flap.
#6 Mixey
Mixey
  • 32 posts
Posted 11 April 2010 - 08:31 PM
thats great. thanks
