Service
Started by
MartinS
, Apr 13 2010 03:12 PM
6 replies to this topic
Posted 13 April 2010 - 03:12 PM
Hi chaps
Car is due its 7th service and hgas doen 43000 miles. Is there any particular thing I should get checked, that wouldnt normally be checked?
Martin s
Posted 13 April 2010 - 03:57 PM
Martin,
I had my 7th service done recently at Guglielmi's, I was on about 37k miles. I checked with Jon at Courtenay beforehand who confirmed there was noting special in terms of additional requirements, my S/C belt fitted last year should still be fine and the supercharger does not need any service work at its age or mileage. I usually get all the fluids changed anyway, including gearbox, have new plugs and get the air filter cleaned (I've got a Jetex cone on the SC).
Steve
Posted 13 April 2010 - 04:02 PM
Thanks Steve all good info. What plugs do you use?
Martin s
Posted 13 April 2010 - 04:11 PM
NGK Laser Platinum Premium PTR5A-10. It's what Courtenay fitted and Steve G has used the same.
Posted 13 April 2010 - 06:11 PM
All depends when all the things were last done. Brake fluid every 2 years min, BOT include it in there yearly service though. Air filter cleaned every year if a foam one, 3 years if original. Spark plugs every 4 years. Fuel filter every 10 years.
Gearbox oil you can leave in for life.
All the above are manufacturer minimums so if you want to do them sooner its up to you
Also consider the alarm batterys if they've not been done for years
Posted 14 April 2010 - 11:37 AM
Thanks lads.
Where can you get those plugs, courtenays?
Martin s
Posted 14 April 2010 - 11:45 AM
Thanks lads.
Martin s
£20.35 for 4 , incl vat
http://www.sparkplugs.co.uk/
