Engine Bay Soundproofing
24 replies to this topic
#1 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 13 April 2010 - 07:49 PM
I don't have any soundproofing/speakers etc behind the seats so thought I'd consider the engine bay side, so has anyone removed the thick fibre material? If so, was it easy and did it make a massive difference to the noise or heat in the cabin?
#2 chris_uk
Posted 13 April 2010 - 07:50 PM
i know rik has done.. dont know how easy it is tho
#3 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 13 April 2010 - 07:51 PM
Nev may have i know hes removed quite a bit of sound proofing.
#4 techieboy
Posted 13 April 2010 - 08:10 PM
I think Vocky and Joe have. :unsure:
#5 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 13 April 2010 - 08:16 PM
:yeahthat:
POP if you're ECU isn't bolted through it! :beat: ha ha! Think I will cut the material around my ecu and remove what I can. The more I can hear the engine and the more weight I can strip the better! :D
#6 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
plus me soon i am cooking the proving very quickly at the moment :rolleyes:
#7 vocky
Posted 13 April 2010 - 08:25 PM
I have no interior shelf, no interior sound deadening and no engine bay deadening - can't tell the difference :wacko: but then I rarely have the roof on when driving rallly
#8 The Batman
Posted 13 April 2010 - 08:30 PM
Yup no sound proofing and was easy to remove! Still debating about taking speakers and cd player out.... Hmmm...
#9 chris_uk
Posted 13 April 2010 - 08:31 PM
do you ever get time to drive it full stop?
#10 vocky
Posted 13 April 2010 - 08:36 PM
I've driven my vx once since last september :( but on a more positive note it's just about finished :D ps: that last sentence might not be 100% true :P
#11 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 13 April 2010 - 08:39 PM
i will be glad to finally hear your car :rolleyes:
#12 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 13 April 2010 - 08:45 PM
Good! Now you can start on mine! :ninja:
:lol:
Look forwardto hearing of your results! thumbsup
#13 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 13 April 2010 - 08:56 PM
Did you unscrew everything that is bolted through it or just cut it out?
And can I do it all through the engine bay or do I have to take the undertray off?
#14 crazy-frog
crazy-frog
  • 11 posts
Posted 13 April 2010 - 09:12 PM
:lol:
can do it for you in a quick easily way....1/2 gallon of petrol and set fire to it
between newbies we understand each over :P
Edited by crazyfrog, 13 April 2010 - 09:13 PM.
#15 rik
rik
  • 2,187 posts
Posted 13 April 2010 - 10:33 PM
u have to unscrew a few pipe clips then reattach afterwards only worth it if you have clam and inlet manifold already off otherwise it'll be a complete arse
#16 The Batman
Posted 14 April 2010 - 03:49 AM
i unbolted everything as i got rid of my heater pipes at the same time ;) well modified them :D you could probably cut round them though! i can only thing of the heater pipe P clips that are bolted to it that will get in your way.. .the rest should just pull off!
#17 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 14 April 2010 - 07:43 AM
i unbolted everything as i got rid of my heater pipes at the same time Posted Image well modified them Posted Image
Thanks. I'll have a look.
Do you ever sleep?
#18 Nev
Posted 14 April 2010 - 01:38 PM
The fibre material only weights approx 1 Kg BTW.
#19 The Batman
Posted 14 April 2010 - 02:02 PM
not when its full of water!
#20 alanoo
alanoo
  • 1,324 posts
Posted 14 April 2010 - 06:08 PM
Honestly, it changes a bit how it sounds, but it is not noisier
