Fan Override Switch
Posted 15 April 2010 - 08:28 AM
Posted 15 April 2010 - 09:56 AM
Posted 15 April 2010 - 10:00 AM
Posted 15 April 2010 - 10:01 AM
Posted 15 April 2010 - 10:03 AM
Posted 15 April 2010 - 10:29 AM
do you run your scangauge when on track?
if so give techieboy a shout as he programmed his to turn the fan on and off via the ECU (eg the proper way). saves knobbing about with relays and switches.
Tried the code before but couldn't get it to work, think it only applies to the NA
Got the dash off at the moment so should be easy enough to route some wires.
Posted 15 April 2010 - 11:20 AM
Posted 15 April 2010 - 01:43 PM
You only have to find the right fan relay ground wire (normally switched to ground by ECU)
Splice in the extra cable for your switched ground and finito.
Edit:
Switching the grey and blue wire to ground however needs no fuse. You're simply manually doing what the ECU does and the live circuit will be running through the relay as designed.
Run a wire back from it to the cabin, connect to switch, connect other pin to a ground, not sure on grounding points in the dash, having not looked yet.
Edited by Exmantaa, 15 April 2010 - 01:45 PM.
Posted 15 April 2010 - 02:23 PM
http://www.vx220.org..... switch&st=20
Edit:
Exxxcellent, exactly what I needed, cheers fella
Just to confirm, grounding the grey/blue doesn't interfere with the normal operation of the ecu?
Posted 15 April 2010 - 02:34 PM
have you got a link to the code or the code? I might try it if so, have a Scangauge and an NATried the code before but couldn't get it to work, think it only applies to the NA
Posted 15 April 2010 - 02:39 PM
You need to program the turn-on and turn-off codes listed at the bottom of this page and assign them to a memory slot on the Scangauge. Works a treat.
Posted 15 April 2010 - 02:44 PM
No, The ECU switches this wire to ground to activate the relay. In case the ecu switches anyway while you grounded this wire by the extra switch, it simply will "ground an already grounded signal"
First do a trial for the right connection (simply stick a piece of wire in) before you start modding.
Posted 15 April 2010 - 03:26 PM
Posted 16 April 2010 - 08:06 AM
Posted 16 April 2010 - 09:29 AM
Posted 16 April 2010 - 11:01 AM
Edited by Exmantaa, 16 April 2010 - 11:02 AM.
Posted 16 April 2010 - 11:48 AM
I must be doing something wrong. I've run a wire from the blue/grey terminal(see picture) straight to the battery earth, ignition on then engine on, any thoughts on why my fan aint doing it's thing.
stupid question... but are you sure the fan actually works under normal ecu operation? i.e does it come on when temps get high?
Posted 16 April 2010 - 12:25 PM
Edited by Exmantaa, 16 April 2010 - 12:25 PM.
Posted 16 April 2010 - 01:05 PM
