Bypassing Inlet Bcs
Posted 19 April 2010 - 10:26 AM
Posted 19 April 2010 - 10:35 AM
Chaps,
As part of debugging the car's boost issue, I'm going to bypass the rear boost control solenoid to see if it is at fault. Is it going to cause me any problems by doing this? A lot of the Astra guys seem to recommend it as a long-term modification anyway, but I'm a little suspicious.
Thanks in advance.
put in a T and connect the Recirc valve larger diameter plastic pipe direct to the same vacuum supply as used by fuel pressure regulator connection, this is just on the vacuum side of the throttle body.
This will eliminate about 6-7 rubber joins , the solenoid, the vacuum storage box.
If you are getting a prolonged turbo chatter noise when quickly shutting the throttle , this will prove the recirc valve / diaphragm.
Really you need a boost meter on the intake to see what is happening.
Posted 19 April 2010 - 10:41 AM
Nice one. Shouldn't take me more than five minutes, got a couple of tees lying round in the garage I can use.
Thanks.
Posted 19 April 2010 - 08:05 PM
Posted 20 April 2010 - 08:34 AM
Ok, after bypassing the rear BCS tonight, I am indeed getting quite a bit of chatter on sudden lift-off. Does this mean everything is working ok as regards the recirc?
what does your boost guage record when driving it part throttle between 2,500 to force the turbo to modulate boost , rather than wide open throttle. Plus do you get good vacuum , no leaks now?
Posted 20 April 2010 - 08:48 AM
Posted 20 April 2010 - 08:46 PM
Posted 21 April 2010 - 11:42 AM
i got exactly the same thing when i bypassed the recirc so put it back to OEM (was tring to remove 2500rpm chatter)
Posted 21 April 2010 - 12:17 PM
scenario 1 - RV connected direct to intake manifold
So when during partial boost , you then rapidly shut the throttle, you should see lots of vacuum in the inlet, this should fully open the Recirc valve.
Provided the diaphragm is in good condition, the boost spike between the turbo and throttle body should have an escape route via the recirc back to intake pipe and atmosphere , instead of stalling the turbo.
Yes you will get a whoosh, instead of a "cha cha cha" stall noise.
Posted 21 April 2010 - 12:48 PM
I see. So the fact I'm getting compressor stall when the vacuum box and solenoid are taken out of the equation would point to a sticking or otherwise faulty diaphragm in the RV, because it should be opening fully and it isn't.
I take it the box and rear solenoid modulate the boost so that I haven't been getting stall before?
I suppose I could further test this by putting a one-way valve between OE recirc and throttle body vacuum pipe, and plumbing in an atmospheric DV.
Edit: I was also seeing very strong vacuum in the inlet on lift-off.
Edited by TankRizzo, 21 April 2010 - 12:51 PM.
Posted 28 April 2010 - 10:06 PM
