Mmg Underdrive Pulley
24 replies to this topic
#1 misterdroid
misterdroid
  • 87 posts
Posted 03 May 2010 - 12:01 PM
Does anyone have experience of the MMG underdrive pulley kit? I have a stage 2 turbo and was thinking of fitting one mainly because of the occasional squeaking that comes from the existing belt when it's damp. Are they worth it, is there much of a performance gain and how easy are they to fit?
#2 VXTyrant
VXTyrant
    Red Rules!
  • 2,198 posts
Posted 03 May 2010 - 12:22 PM
Removes 4.5kg of weight and allows the engine to spool up quicker. Makes revving alot free-er! Worth doing for £150 and not exceptionally hard to fit!
#3 redvts
redvts
  • 1,472 posts
Posted 03 May 2010 - 12:25 PM
Does make a little bit difference, u get to throw some bits away from ur engine too lol the tensioner plus some other bits, gets rid of that really annoying squeaking in the rain too, not to bad to fit, can be a struggle to get the old pulley off but apart from that it's fine
#4 Whiteboy
Whiteboy
  • 6,950 posts
Posted 03 May 2010 - 12:34 PM
I went for the courtenays one at £99. It got rid of the squeak when wet and saved 7.5kg of pig iron. I was amazed that the engine response was so much better. :jump:
Edited by Whiteboy, 03 May 2010 - 12:35 PM.
#5 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 03 May 2010 - 02:20 PM
Fitted mine a couple of months ago, really surprised with the results in a positive way. Fitting is a bit of a pig, if you want to remove all of the other gubbins. Make sure that you have some ratching spanners.
#6 misterdroid
misterdroid
  • 87 posts
Posted 03 May 2010 - 04:18 PM
Thanks chaps, I may go for the Courtenays one as they did the Stage 2 map.
#7 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 03 May 2010 - 04:19 PM
I just threw away the extra bits, and bought a shorter belt for about £9, also saves almost as much weight and gets rid of the squeak. If I remember right a 917mm belt fits directly but with possible issues with the oil unions, a 900mm belt requires a mod to the alternator bracket but gives more clearance for the oil unions.
#8 jbudgie
jbudgie
  • 521 posts
Posted 11 October 2010 - 07:08 PM
Just got a Courtenay pulley, can someone please confirm exactly which is the correct belt to get . Thanks.
#9 Mitch01
Mitch01
  • 80 posts
Posted 11 October 2010 - 08:11 PM
I brought one (underdriven pulley) back from Courtenay's on Saturday which was supplied with a 5PK858 belt, but have not fitted yet. I was told that the belt will fit with no mods to the alternator bracket. Hope this helps. Mitch
#10 TankRizzo
TankRizzo
  • 475 posts
Posted 11 October 2010 - 08:34 PM
How easy is this to fit, fellas? I take it it's ring spanner around the tensioner, move the tensioner back, pop old belt off, remove ancillaries....then what?
#11 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 12 October 2010 - 09:38 AM
Does not save anymore than 5kg ;) weighed all the oe bit last week when fitting one as I forgot what they were and weighed the MMG one. There is nowhere to gain another 2.5kg ;)
But 5kg is a lot for what it is and does remove a lot of redundant kit freeing up revs :P
Once belts off with method you state its just removing all the bits and not hard if you have the correct tools (torx) Sure its E12 & E14
DG
#12 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 12 October 2010 - 09:43 AM
I'm going to do this over winter!
#13 dw1
dw1
  • 3,043 posts
Posted 12 October 2010 - 09:52 AM
I haven't seen the others but I am impressed with the mmg one, it is a lovely bit of kit cast out of a solid aluminium billet, it came with a tensioner so you can adjust over time if necessary. I got Liam to fit it at the same time as a service because I am about as mechanical as a snail.
#14 siztenboots
Posted 12 October 2010 - 09:55 AM
I've had my 858kit on now for just over 2 years. Still original belt and the ttv pulley. thumbsup
#15 VXTyrant
VXTyrant
    Red Rules!
  • 2,198 posts
Posted 12 October 2010 - 11:47 AM
I was very impressed with the kit I received from MMG about a year back now. The quality was fantastic and the mod is well worth it too! As Duncan says - it won't save you anymore than 5kg of weight!
#16 VXT Tim
VXT Tim
  • 11,421 posts
Posted 12 October 2010 - 05:27 PM
http://www.mmgperfor...the-vx220-turbo Does this include the short belt? 12-15hp :unsure:
#17 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 12 October 2010 - 05:40 PM
12-15hp :unsure:
Pretty sure that includes the belt.
#18 VXT Tim
VXT Tim
  • 11,421 posts
Posted 12 October 2010 - 05:45 PM
12-15hp :unsure:
Thanks bud.
Mmg £159.21
CS £105.95
I take it there can't be much difference in the kits?
#19 turbobob
turbobob
    2/3rds of a Queen
  • 13,833 posts
    Photography
    CARS!!
    Travelling
Posted 12 October 2010 - 05:52 PM
12-15hp :unsure:
Thanks bud.
Mmg £159.21
CS £105.95
Isn't the Courtenay one just the pulley, whereas the MMG is the kit (including tensioner bracket and belt)?
#20 VXT Tim
VXT Tim
  • 11,421 posts
Posted 12 October 2010 - 05:54 PM
Hhmmm you might be right, the pulley is £95, the belt £10.95. Will go have better read.
