Wheel Weights
Posted 29 April 2004 - 06:42 PM
Posted 30 April 2004 - 04:41 AM
Posted 30 April 2004 - 10:29 AM
Those are the multi-spoke you've got, not the 5-spokes, right? I've added them as such.Speedline (Turini)
16" Front - 7kg's
17" Rear - 7.3kg's
N/A stock front 9.8kg,
N/A stock rear 11.6kg
VXT stock front ?kg,
VXT stock rear ?kg
VXR Speedlines 5-spoke front ?kg,
VXR Speedlines 5-spoke rear ?kg
Steinmetz ST3 5-twin-spoke 7x16" front ca. 8kg,
Steinmetz ST3 5-twin-spoke 7.5x17" rear ca.10kg
Speedline (Turini) Multi-spokes ?x16" front - 7kg,
Speedline (Turini) Multi-spokes ?x17" rear - 7.3kg
Anyone know weights for the VXR Speedlines yet?
Posted 30 April 2004 - 03:27 PM
Posted 30 April 2004 - 04:25 PM
Posted 30 April 2004 - 09:16 PM
Posted 01 May 2004 - 07:01 AM
Posted 01 May 2004 - 07:07 AM
I think that the manufacturing quality also is a factor. Since wheels are round a process called "low pressure casting" can be used, the aluminium simply flows from the center into the mould. In "high pressure casting" a strong pressure is used, look at the covers on a motorcycle engine for instance, thin and strong. Some of the high quality wheels are probably better made with stronger material.I'm seriously considering the VXR wheel/tyre package if there is a real weight saving or what Thorney has. Is there a compromise however in terms of durability / fragility and weight or are the two simply not linked?
(Ricky has made that observation, the standard N / A wheels easily scratch)
Posted 02 May 2004 - 09:42 AM
What was the cost for wheels and hubs?
Posted 02 May 2004 - 09:51 AM
Posted 02 May 2004 - 09:57 AM
Posted 02 May 2004 - 10:44 AM
Posted 02 May 2004 - 12:01 PM
Posted 02 May 2004 - 12:13 PM
IIRC, Thorney said ali hubs £60 (each???).Just pricing up my options.... how much were the hubs? Need to add brake discs too!! But i bet ali bells are avaialble too
Definitely the way to go if you can, as unsprung weight is very relevant in such a light car. I wouldn't get it passed in Switz. unfortunately (another reason to consider 111r).
Posted 02 May 2004 - 03:33 PM
Posted 02 May 2004 - 05:01 PM
Posted 02 May 2004 - 05:23 PM
Posted 02 May 2004 - 07:32 PM
can you give me a total for all four hubs?.I can get you hubs, I get them direct from Lotus so you need a trade account there (which I now have). I don't make any profit on em (you'll find that with Lotus stuff) but I'm happy to help out so long as I cover the costs and postage.
They bolt straight on.
Posted 03 May 2004 - 08:56 AM
Posted 03 May 2004 - 11:00 AM
Do they have the correct offsets and no need for spacers?Here's the toora wheel for your table, i think this is still a no-no for the switz authority though.
VXT stock rear ?kg
Toora front 6.5x16" 8kg
Toora rear 7.5x17" 9kg
