Started Smoking At High Oil Temps. Turbo Oil Seals . .
Posted 27 May 2010 - 09:02 PM
Posted 27 May 2010 - 09:16 PM
Right the VX has started smoking once up to around 95 degrees now and then, obviously turbo oil seals on there way out.
My question is does this really matter as im going to the ring in 5 weeks or so. Thinking i'll just leave it until I return to replace the turbo . . . . or is this a bad idea and need to get working to replace before (VXR Turbo).
What do you think.
Sam
Burning oil for long periods is obviously not very good for the engine. First port of call though is to try a thicker oil (10w50) and see if that sorts it out or atleast delays it for a while longer. I take it you warm up and cool down correctly too
Posted 27 May 2010 - 09:27 PM
Posted 27 May 2010 - 09:33 PM
Posted 27 May 2010 - 09:52 PM
you may want to take the pipe to you intercooler off to see if theres oil in there as it may be leaking the inlet side aswell. Then that oil would be going through your engune. 5 weeks is plenty of time to get a second hand Let turbo or a vxr unit on though
Good advice will do, whats considered alot of oil as obviously there will be some?
Your right 5 weeks is plenty.
Posted 27 May 2010 - 09:58 PM
Posted 28 May 2010 - 05:50 AM
Posted 28 May 2010 - 07:11 AM
Edited by sam220T, 28 May 2010 - 07:13 AM.
Posted 28 May 2010 - 08:50 AM
Posted 28 May 2010 - 10:25 AM
The silicone breather hose pictured here
As it is very close to the manifold it gets hot and perished quite easily, as you can see my was quite bad.
It was leaking oil, and although i had no smoke there have been reports of the oil dripping onto the manifold and burning off. Think it was Nev actually.
Posted 28 May 2010 - 10:54 AM
Posted 28 May 2010 - 01:11 PM
Posted 28 May 2010 - 01:23 PM
I'm getting smoke from the exhaust on tick over when the oils quit hot, also really smells of burning oil. Seen this three times now after a blast is quit a lot of smoke, clear to see.
Rules out my late option then.
Posted 28 May 2010 - 02:08 PM
Posted 28 May 2010 - 02:45 PM
