Oil Leak
Posted 29 May 2010 - 01:53 PM
Posted 29 May 2010 - 02:11 PM
Posted 29 May 2010 - 02:17 PM
Posted 29 May 2010 - 02:22 PM
Posted 31 May 2010 - 05:45 PM
Posted 31 May 2010 - 05:51 PM
Posted 31 May 2010 - 06:12 PM
Posted 31 May 2010 - 06:17 PM
Bloody hell I didnt relise it was 120 NM no wonder mine was leaking. Funnily enough last weekend I tightened it as much as a dared and its actually stopped leaking. Good job as there is apparently no UK stock of the metal seals!
http://www.speedster... Replace (Z22SE).pdf
Install, then secure securing ring (1), using Remover/Installer KM-6264 120Nm
The cap itself only needs 18NM, but as far as I can see it the only way to tighten the collar beneath it if that is luose is to over torque the cap...
Posted 31 May 2010 - 10:47 PM
It looks like you're supposed to use a 'C Type' spanner, similar to the ones used for shocks, or even a screwdriver and hammer, but in that case I'm not sure why they'd give a torque valueThe cap itself only needs 18NM, but as far as I can see it the only way to tighten the collar beneath it if that is luose is to over torque the cap...
Posted 01 June 2010 - 08:10 AM
Posted 01 June 2010 - 08:37 AM
Posted 05 June 2010 - 07:23 PM
Posted 16 August 2010 - 01:24 PM
Posted 16 August 2010 - 04:46 PM
it will be a big round socket with lugs on to let you torque it up.
you could probably make up something with angle iron and a socket you dont mind welding to the X of angle.... We made tools up like that for fitting diff retaining 'nuts' (its the size of a CV joint lol) etc.
I tell you what if someone came up with a tool to tightenthat fcuker up properly (I can't see how it would be possible even with the dedicated Kent-Moore tool.
That would definitely be a tool I would invest in!
Posted 16 August 2010 - 04:53 PM
