Brake Cooling Ducts
Posted 13 June 2010 - 05:32 PM
Posted 13 June 2010 - 05:37 PM
Posted 13 June 2010 - 05:38 PM
Posted 13 June 2010 - 05:39 PM
Edited by styles, 13 June 2010 - 05:40 PM.
Posted 13 June 2010 - 05:41 PM
Posted 07 January 2017 - 08:17 PM
[color=rgb(90,90,90);font-family:helvetica, arial, sans-serif;font-size:12px;background-color:rgb(247,251,252);]I'm in the process of fitting an uprated ARB so thought i'd get rid of the useless fog lights and fit some brake ducts. I'm struggling to see a suitable route for the ducting, looks like going through the rad housing is the only option? Not too keen on cutting that! [/color]
Posted 08 January 2017 - 04:13 PM
This is the only option (if you don't want to cut the chassis).
or something like this
Edited by 2-20, 08 January 2017 - 04:13 PM.
Posted 08 January 2017 - 06:03 PM
Posted 08 January 2017 - 07:11 PM
Posted 09 January 2017 - 03:47 PM
I use bits from revotec, make sure you get the clips that hold the pipe on to the side else they can rub on the tyres.
Martin S
Posted 09 January 2017 - 07:05 PM
This is what you need http://www.vx220.org...-cooling-ducts/ I have them fitted, I fitted them when I was using 1144's and they did make a difference
Going to unashamedly bump that thread..
Posted 09 January 2017 - 07:45 PM
Posted 09 January 2017 - 08:15 PM
Mine fit to the back of the fog light holes and pass through the radiator housing (the bits that hang down behind the fogs). They point 45deg toward the discs. I think I brake fairly late and aggressively though I'm no racer, Simon has been out on track with me to comment, but they don't really overheat at all any more whereas 10-12 minutes on most circuits and the abs would start pulsing earlier and earlier.pete_r has some very nice rigid ducts fitted to his. Not sure how it was done though.
Posted 09 January 2017 - 08:20 PM
I didn't want to go any faster! :I think I brake fairly late and aggressively though I'm no racer, Simon has been out on track with me to comment, but they don't really overheat at all any more whereas 10-12 minutes on most circuits and the abs would start pulsing earlier and earlier.
