P1221
Posted 17 June 2010 - 07:10 PM
Posted 18 June 2010 - 05:53 AM
Z22SE specific codes:
http://www.speedster.../z22secodes.pdf
Or more details on pins and wiring as well on THIS PDF
Edited by Arno, 18 June 2010 - 05:54 AM.
Posted 18 June 2010 - 07:40 AM
Posted 18 June 2010 - 10:26 AM
Edited by snoopstah, 18 June 2010 - 10:27 AM.
Posted 18 June 2010 - 11:15 AM
Posted 18 June 2010 - 01:18 PM
On a similar issue.. I assume that installing the ITB kit would more than likely eliminate this issue? It's something I was considering having done in the not too distant future.
I've a spare ecu set if it comes down to it.
Thanks FLD, I'll bear that in mind!
Posted 19 June 2010 - 01:36 PM
Posted 19 June 2010 - 01:39 PM
Hi guys, I've a simiar Throttle position problem: codes are
Any ideas where I go from here?
thanks,
k.
Sorry the codes are:
1515 - Command versus Autual Throttle Position Correlation
1516 - Throttle Actuator Control Position Performance
thanks,
k.
Posted 19 June 2010 - 08:11 PM
Just from how they sound, I'd be going for a problem with the throttle body itself (or the servo) rather than the pedal, wiring or anything else discussed here.Sorry the codes are:
thanks,
k.
Cleaning it with carb cleaner is a simple first step, and you may get lucky and that's all it needs!
Posted 19 June 2010 - 08:18 PM
Posted 12 July 2010 - 09:16 AM
Posted 12 July 2010 - 09:42 AM
Take it back to the dealer and get them to fix it and get a loaner in the meantime?Anyone got any ideas?
Posted 12 July 2010 - 12:03 PM
So P1221 has gone now, and after a week of hassle free driving the car died on the M4 yesterday.
I'm now getting:
P1512 - Throttle Position Minimum Learning not completed
P1515 - Command versus Actual throttle Position Correlation
So far:
Pedal sensor changed.
Plugs behind expansion bottle checked and cleaned.
Throttle body changed. (This cleared the P1221).
The car starts fine, but when running the revs are all over the place and dont appear to settle. When I turn off the ignition it shudders to a halt rather than cutting off cleanly. Throttle pedal is not doing anything.
I had these. Its down to the throttle not doing what the pedal tells it to do. Its not that the contacts are corroded but they are loose (no current to the drive motor). Its the blue plug and if you pull it open, remove the yellow mesh, then look at the contacts you will see whichever one is loose. Poke a pin in and close it up. You can get replacement contacts if need be. I tore my hair out over this one!! Also worth making sure the blue and black plugs are pushed home fully.
Posted 12 July 2010 - 03:33 PM
They did check the connector, but would they be able to tell if the contacts are loose just by looking at the end, or would it require a bit more digging? Might be easier to ask them to replace the connectors - do you have a link to any online?
Cheers.
Posted 12 July 2010 - 07:59 PM
Its not immediately obvious if your looking for corrosion. If you look right down the centre of the terminal there is a sort of clamp piece that makes the contact. If the wiring is free to move it levers open the terminal. You can see that its moved back if you look down each terminal. You can push them back with a pin or they are 8070's from vehicle wiring products. Its worth checking that the plugs are pushed right home as the last few mm are really hard. If thats right in (ooer) then give the wiring a wiggle. If that cures the problem its a loose connection here. The wiggle fix wont last but it helps pin it down.
Cheers.
Posted 12 July 2010 - 08:00 PM
Posted 12 July 2010 - 09:26 PM
Posted 13 July 2010 - 11:11 AM
Cheers for the info. No opcom unfortunately
Car's at the garage again - they're sticking the tech2 on it tomorrow so I'm hoping that they'll find something there.
I'm hoping to have ITB's added in the near future so I'm not too keen on chucking too much more cash at it.. but on the other hand I want it back on the drive
[/quote
just had this on mine after alot of buggering about. it turn out to be water in the waterproof plugs on the ecu! youll have to unbolt the ecu and clean and dry out (hairdyer ???). also 1 blot will need drilling out to get the ecu off!
stu
Edited by vectraboyv6, 13 July 2010 - 11:12 AM.
Posted 13 July 2010 - 02:59 PM
stu
Hmm thanks, that could be an option to look into. How much effort is involved with checking the ECU plugs? The other thing is, it's not rained for ages and the car was running perfectly well once the T/B had been changed. (Until sunday anyway). It's been like this on and off now for a good few weeks, albeit now with slightly different throttle related error codes.
Posted 13 July 2010 - 03:10 PM
