Gearbox Breather
Started by
old codger
, Jun 19 2010 02:43 PM
7 replies to this topic
Posted 19 June 2010 - 02:43 PM
I have seen the different gearbox breathers, where some have the catch tanks, and some have hose and in line breather. What type of breathers are people using? They seema lot better value than the alloy catch tanks. Does anyone use the hose alone with no breather, and where is the best position for the hose once fitted?
Posted 19 June 2010 - 02:46 PM
hose and a breather will be fine. Breathers are less than £5. route it up to next to the header tank
Posted 19 June 2010 - 02:58 PM
Yes what sort of breather? I was in motorist shop and they had fuel breathers, but will they be ok? Or is it a specific breather just for the gearbox?hose and a breather will be fine. Breathers are less than £5. route it up to next to the header tank
Posted 19 June 2010 - 03:26 PM
There's a guide here somewhere but a piece of fuel pipe works OK. I had it on an NA without a catch tank and I don't think anything ever made it to the top of the pipe as it was always clean. Turbos spit out more it seems.
Posted 19 June 2010 - 10:56 PM
if you have an old bit of hose pipe you can just make one.
i did it for mine see below.
Posted 20 June 2010 - 12:12 PM
I have used a 13mm fuel pipe and put a little filter on the top.
Steve
Posted 20 June 2010 - 12:20 PM
