Code P1515 And P1516
Started by
ken355
, Jun 22 2010 09:21 AM
3 replies to this topic
Posted 22 June 2010 - 09:21 AM
Hi Guys,
Got 2 error codes on the car. P 1515 and P 1516. Car will start but then cuts out within a minute.
I think these codes mean the following: P1515 Command versus Actual throttle Position Correlation and P1516 Throttle Actuator Control Position Performance..I think these are the right faults for these codes but can someone please confirm.
I've already removed the rear wheel and wheel arch lining and cleaned the Blue and Black connectors (As Reccommended by FLD) and I've cleaned the Orange connector at the bottom of the over flow tank. Still wont run.
Any ideas? Feel like the car is doing this to me:
Posted 22 June 2010 - 11:12 AM
Clean the plugs on the throttle pedal (feet in the air neck bending experience!) and the plug on the throttle body itself and see how you get on.
Posted 22 June 2010 - 04:27 PM
Hey Darryl,
When i look under the pedal, I see a balck box about 3 inches squared with clips on the side and below that a plug with a red top about and inch squared with wires coming out of it - Do I need to open the red plug and if so how? Dont want to break anything.
also - where on the car can I find plug on the trottle body?
Thanks for your help,
ken.
Posted 23 June 2010 - 10:44 AM
Hey Darryl,
ken.
Thats the sucker! I'll reply to your PM now :-)
