Replacement Meta Alarm From Abacus
Posted 28 July 2010 - 07:48 PM
Posted 29 July 2010 - 07:01 AM
No need to change any wiring, this really is a plug and play fitment (unless you have central locking, in which case you have to plug an extra wire in - full instructions were included, and the guy at Abacus is very knowledgeable). You'll probably find there is no need to replace the interior sensor (the kit comes with ultrasonic sensors - no good for soft tops) as they rarely go wrong.
As a bonus it will not be affected by wireless doorbells!
Edited by pjohn151, 29 July 2010 - 07:03 AM.
Posted 29 July 2010 - 07:16 AM
Posted 29 July 2010 - 07:17 AM
I had the replacement unit, but have never noticed an interior sensor. Do all vxs have them ?I've fitted one of these as my alarm siren was in pieces and the remotes were missing
Posted 29 July 2010 - 08:01 AM
There is a microwave sensor (detects movement) behind the rear bulkhead panel. Sits roughly between the shoulders of driver and passenger. It is adjustable and should activate as soon as you put your arm within the cabin area, with the roof on or off. You need to remove the speaker panel to get access though if you find you need to adjust it. Most should have been set reasonably well at the factory.
Edited by garyk220, 29 July 2010 - 08:01 AM.
Posted 29 July 2010 - 11:32 AM
Cheers guys. Will get one ordered
Some too well!
It is good that the minute I put anything on the soft-top it sets the alarm off. But is definitely effected by the doorbell of the house opposite. Only have one fob myself, so will be replacing it in a couple of months time.
Posted 29 July 2010 - 11:48 AM
well!
LOL same with me, but its my sky remote that does it when im using the wireless IR sender thing to change channel from my room! always at night when every ones a sleep!
how much does the unit cost? and when it comes to fitting what spanner rating is it?
Posted 29 July 2010 - 12:16 PM
Posted 29 July 2010 - 07:12 PM
Posted 08 August 2010 - 03:11 PM
Posted 08 August 2010 - 04:07 PM
Posted 08 August 2010 - 06:40 PM
Posted 09 August 2010 - 08:23 AM
Posted 09 August 2010 - 11:07 AM
Posted 09 August 2010 - 12:26 PM
Posted 10 August 2010 - 07:57 AM
