Why Does The Vx Do This After A Spin?
Posted 30 July 2010 - 10:39 AM
First time you can see in the vid here at 0:45 in. Car has stalled in the spin, try starting it but it needs quite a bit of turnover to get going (almost like it's flooded), once it's started and I move it out of the way you can hear the motor revving up and down (is searching for idle the correct term?). Turning it on and off fixes the problem.
Second time at Oulton Park spun around the bend at the end of the straight, ended up facing the right direction and motor doing the revving thing, again restart fixed the problem.
Also both times the EML came on. 10mins with fuse 8 out fixed it both times.
A guy who had previously owned a VXT mentioned it was probably because I didn't clutch in time and going backwards has forced the motor to turn the wrong way which is why the EML comes on.
Any techy gurus have an explanation?
Posted 30 July 2010 - 10:54 AM
Posted 30 July 2010 - 10:57 AM
Posted 30 July 2010 - 11:05 AM
Posted 30 July 2010 - 11:07 AM
yep, engine has spun backwards and thrown exhaust gas into the intake.
takes a few turns to clear.
clutch in earlier (or dont spin)
Done
and the revving it's doing by itself?
It is telling you that you should cease doing track days.
Posted 30 July 2010 - 12:34 PM
its to give time for the sc's to catch up
Posted 30 July 2010 - 12:54 PM
Done
need I remind someone of a certain vid of Le Mans?
Not at all, it was telling me to give up track days as well.
Posted 30 July 2010 - 12:58 PM
its to give time for the sc's to catch up![]()
he's not biting
Posted 30 July 2010 - 01:23 PM
Say what?
he's not biting
He will
Edited by turbobob, 30 July 2010 - 01:24 PM.
Posted 30 July 2010 - 01:35 PM
Posted 30 July 2010 - 01:43 PM
That'll be the itb's thengoing to slow
Posted 30 July 2010 - 02:32 PM
itb's then
no way got the graph available to post
Posted 30 July 2010 - 02:38 PM
Meh, still slower than a stage 2 tubby
itb's then
Posted 30 July 2010 - 03:10 PM
can you drive it the proper way
Posted 30 July 2010 - 03:17 PM
Yeah. I'm not a woman
Posted 30 July 2010 - 05:13 PM
Posted 30 July 2010 - 06:50 PM
Meow
just heard you drive like one
