Is there anything I need to know about removing the airbag...? Obviously wish to avoid it deploying in my face
How does it come out, and how do I rem,ove the squib.
Any info on what I need to change over to a sparco type wheel would also be appreciated
Airbag is easy. Ignition off, 2 bolts on th back of the steering wheel, and pull the tab out of the connector.
If you can put a new wheel on the hub then great. Taking hub off is a PITA.
I've done this too many times.
ignition off and key out
undo airbag bolts x 2
remove airbag, and disconnect the yellow/blue connector
remove allen bolts for steering wheel then wheel comes off
loosen steering shrowd by removing all screws
remove centre (green) bolt holding boss on
use boss remover tool (trust me you need one) to remove the boss
once boos is 'loose' use allen key to remove the silver screws that is holding the squibb in
remove
ECU is just 4 bolts under the dash and the pink/yellow (or pink/green) connector
