Sc Conversion Error Codes
#41
Posted 25 August 2010 - 02:04 PM
#42
Posted 25 August 2010 - 02:13 PM
Edited by davemate, 25 August 2010 - 02:18 PM.
#43
Posted 25 August 2010 - 03:10 PM
i didnt either, but am really trying to try everything
any tips on how to swap wires out on the ecu, there is a pinch on wire 31, but its right up close to the conector and therefore i have no spare to cut, strip and solder... tips please?
can i push out the wire from the other side and reuse the internal connector?
You can usually buy a new terminal (vehiclewiringproducts) then just shorten up the wire a touch if its that close to the terminal. You shouls find a little latch in the terminal that you'll need to push to release it. Its small and fiddly but do-able.
#44
Posted 25 August 2010 - 04:25 PM
#45
Posted 25 August 2010 - 04:43 PM
#46
wish me luck
#47
Posted 25 August 2010 - 05:25 PM
#48
Posted 25 August 2010 - 05:28 PM
#49
Posted 25 August 2010 - 05:38 PM
Edited by davemate, 25 August 2010 - 05:38 PM.
#50
Posted 25 August 2010 - 05:48 PM
#51
Posted 25 August 2010 - 06:00 PM
#52
Posted 25 August 2010 - 06:16 PM
Doesnt matter what way round you wire injectors they will still work i recon its your t/b wiring-news!
fiddled with the relay and it is now priming the fuel pump and there is now fuel going through the system (pressed the little valve and fuel squirted out)... it just isnt coming out if the injectors when trying to start up. gah!
going to swap the wires over on the injectors see what that does.
#53
Posted 25 August 2010 - 06:28 PM
#54
Posted 25 August 2010 - 06:31 PM
#55
Posted 25 August 2010 - 06:48 PM
#56
Posted 25 August 2010 - 06:53 PM
#57
Posted 25 August 2010 - 07:02 PM
#58
Posted 25 August 2010 - 07:05 PM
thanks! reassurig that these problems happened elsewhere.
the irst injector wasnt pumping anywhere near as much air as therest so we have taken this off turned out it wasnt as good a connection as the rest. good call on the priming, tried it 2 maybe 3 times to prime but will give it more juice.
did you replace your return valve in the end- was it actually at fault, and contiue to fail or was it ok once it was fully primied?
Once primed it ran fine but I had to do this every time I started it. New pump job on mine.
#59
Posted 25 August 2010 - 07:25 PM
#60
Posted 25 August 2010 - 08:16 PM
Edited by davemate, 25 August 2010 - 08:19 PM.
