Sc Conversion Error Codes
#61
Posted 26 August 2010 - 03:14 PM
#62
Posted 26 August 2010 - 03:34 PM
#63
Posted 26 August 2010 - 03:43 PM
#64
Posted 26 August 2010 - 04:08 PM
#65
Posted 26 August 2010 - 04:18 PM
Edited by davemate, 26 August 2010 - 04:30 PM.
#66
Posted 26 August 2010 - 05:16 PM
Edited by leevx2.2, 26 August 2010 - 05:17 PM.
#67
Posted 26 August 2010 - 05:20 PM
quick question on the rocker cover there is a black box where a wire goes in is this conected ?it is near the coil pack plug earth strap
yep thatis on there, wealso swapedin another one just in casethis was faulty.
-trying to check earthing points.
-seems that mine is somewhat different (colours, earthing points etc) out of the factory in comparison to some of the other examples i have seen on the internet and advice on here.
going to try and earth the ECU with a new cable and see if this does anything.
#68
Posted 26 August 2010 - 05:28 PM
Edited by FLD, 26 August 2010 - 05:29 PM.
#69
Posted 26 August 2010 - 05:32 PM
i have another wiring loom in the garage you could borrow
#70
Posted 26 August 2010 - 05:38 PM
#71
Posted 26 August 2010 - 06:05 PM
You already tried to push the inertia switch I guess ?
If he's getting fuel pressure this should be fine shouldn't it?
#72
Posted 26 August 2010 - 07:34 PM
#73
Posted 26 August 2010 - 08:04 PM
#74
Posted 26 August 2010 - 08:18 PM
#75
Posted 26 August 2010 - 09:52 PM
#76
Posted 26 August 2010 - 10:21 PM
#77
Posted 27 August 2010 - 10:11 AM
#78
Posted 27 August 2010 - 10:27 AM
Another one... did you at one moment turned the ignition key with the ECU not plugged on its connectors ?
What would that do?
#79
Posted 27 August 2010 - 11:09 AM
#80
Posted 27 August 2010 - 11:14 AM
What would that do?
It can block the immobilizer, I saw that a few months ago on a VXT
Only solution was going to a dealer...
