Gaz Gold Pro Advice
Posted 27 August 2010 - 06:55 PM
Posted 27 August 2010 - 09:35 PM
Posted 28 August 2010 - 08:50 AM
Posted 28 August 2010 - 09:54 PM
Posted 28 August 2010 - 09:57 PM
Posted 29 August 2010 - 12:04 PM
Posted 29 August 2010 - 12:47 PM
I found the dampers really control the bouncyness a lot!!!
set approx 30% from full soft and go from there
The dampers are there to control the bounciness, that is why they are called dampers.
If the spring rates are not right, it wont matter what you do to the damper settings, you cannot make up for incorrect spring rates with damper adjustments.
Posted 29 August 2010 - 02:49 PM
Posted 30 August 2010 - 09:26 AM
pedantic mofo...
Weve all seemingly tried from silly hard to silly soft springs and the dampers appear to cope fine with the range of adjustment available in the nickles or golds (or nitronzzzzzz)
Full soft on silly hard springs wasnt that 'bouncy' whereas full soft on soft springs was like a pogo stick
Posted 30 August 2010 - 09:54 AM
pedantic mofo...
I know, it was only because it was you.
There are so many opinions on what is best for spring rates but it really depends on what you want to use your car for. More track focussed cars will want stiffer springing on a lower ride height whereas a road car will have softer springing and a higher ride height.
Damping should then be adjusted to suit the individual.
You can of course stay on standard Bilstiens and have no choice in the matter.
Posted 30 August 2010 - 05:55 PM
Posted 30 August 2010 - 07:06 PM
Posted 30 August 2010 - 07:09 PM
Posted 31 August 2010 - 07:31 AM
Posted 31 August 2010 - 05:16 PM
Posted 02 September 2010 - 11:17 AM
Edited by oakmere, 02 September 2010 - 11:17 AM.
Posted 02 September 2010 - 01:19 PM
Posted 02 September 2010 - 01:48 PM
I have 22 clicks in total. I'm curently on 5 front and 7 rear. Its a little harder than I'd like but its close. I'm running -4mm on standard ride height due to all the darn speed humps round here! Nearly there. Thanks for all the tips and thanks to noplex for the shockers.
I have noticed just one click down on the rears can make a big difference at the softer end of the settings. I am running approx 123mm front and 133 rear and I have a Phoenix geo.
Good luck
Cheers Oakmere
Posted 03 September 2010 - 09:34 AM
Posted 03 September 2010 - 09:19 PM
Been smoking round in it for a while now and think I'm about there. MUCH less crashy over bumps, wish I'd done it ages ago. I do get a bit more road noise but I guess this si down to rose joints rather than bushes. The swooshing noise is a bit wierd too but I'll get used to it. I dont get the squat I had before either. Overall much better. I'm still getting a hot rubber plastic smell so I think something is rubbing somewhere, liner or tyre but I cant find it!
Overall, chuffed!
My wheels were rubbing on arch liner at 110/120 ride height. Only slight and no smell. Could be soothing unrelated?
