Posted 27 August 2010 - 08:12 PM
Posted 27 August 2010 - 10:57 PM
The zimmermobile's once again got engine problems.....
No EML codes
It was running fine for the north east meet, then I went out for a moderate drive with the missus and it seems to have developed an intermittent misfire.
First time was slowing down for a roundabout on a dual carriageway, 70mph to 15ish through the gears, then when I try to accelerate gently in 2nd, it starts to sound like a subaru. Foot down a bit more and it clears spontaneously after a few seconds.
I cannot reproduce it every time but it appears to only happen when engine is warm, only when slowing down from speed then gently accelerating.
If I don't accelerate when it occurs, the misfire continues until I accelerate or let it idle.
I have a piper exhaust which pops and burbles a lot, and it seems to happen mostly if I accelerate when it is burbling (ie on the overun at low revs) - not sure if this is significant.
Now I had similar problems earlier in the year. First time was a duff injector. Second was where I had swivelled the EGR and not tightened the blanking plate properly leading to a leak which gave similar symptoms.![]()
Therefore it has had a new coil pack, new plugs, replacement ecu, four reconditioned injectors (off ebay) all within the last 6 months.
I also replaced the coolant temperature sensor - with the new one I was only reaching temps of 81-82 degrees. Having swapped back to my old one, the temp's now back to normal but it hasn't cured the problem.
The EGR blanking plate is secure with gasket in place. The EGR valve is swivelled round - removing it brings up the EML but has no effect on the running problem.
I have a courtenay panel filter and drilled airbox, I can't see an obvious air leak.
The manifold is standard.
Car has done 40k miles and was serviced last month (though they didn't replace the oil filter as had no seals, and told me fuel filter didn't need doing yet) Oil and coolant levels are fine.
No rattling to indicate timing chain problems (and surely this would cause constant misfire)
I'm running out of ideas - it feels to me like a fuelling issue, but I haven't really got a clue.
Has anyone had anything similar?
Any ideas where to start?
Help!
Posted 28 August 2010 - 11:15 AM
Posted 28 August 2010 - 03:38 PM
Posted 29 August 2010 - 12:28 AM
Posted 29 August 2010 - 09:45 AM
I've heard the pre-cat lambda can cause trouble before giving a code. I did change mine last year but it was an ebay job, so could be that it's on its way out.
Plugged it into my OBD reader, it's not showing anything
Exhaust is very blackened, maybe it is running rich.
Thanks for the advice, might be worth getting a new lambda sensor anyway
Posted 21 October 2012 - 04:33 PM
Posted 21 October 2012 - 06:40 PM
Posted 13 November 2012 - 10:34 PM
Posted 14 November 2012 - 10:18 AM
Edited by Detta, 14 November 2012 - 10:18 AM.
Posted 14 November 2012 - 10:49 AM
Posted 14 November 2012 - 10:54 AM
I'm having similar symptoms, but not nearly so pronounced. It has just developed that 'Subaru sound' on gentle acceleration between around 2.5-3k and is running a little rich. As above applying more power clears it up.
Being a total noob myself how easy is it to get to the pre-cat lambada sensor, is it tray off, under the car somewhere pre-cat as one would expect?
And is it safe to run without for the sake of testing evo2avxr?
Posted 14 November 2012 - 12:47 PM
Edited by Detta, 14 November 2012 - 12:49 PM.
Posted 14 November 2012 - 12:48 PM
Posted 14 November 2012 - 01:49 PM
Is there an easy way to diagnose if it is at fault without having to drop £50 on a hunch?
EDIT: p.s. it's a Tubby.
Posted 14 November 2012 - 02:12 PM
Posted 02 March 2013 - 09:15 PM
