Edited by Hark, 08 September 2010 - 09:30 PM.
Why Do So Many On Here Run Team Dynamics Wheels?
Posted 08 September 2010 - 09:22 PM
Posted 08 September 2010 - 09:29 PM
Posted 08 September 2010 - 09:30 PM
I know their lighter but have no idea by how much.
Do other wheel suppliers like BBS etc not do the odd fitments that the VX needs? I did a quick search but there were 280 topics...
I think its because generally they are the only ones that fit straight on and in the 16in/17in combo that is accepted as the best handling wise.
Compomotive do the same sizes in the speedline VXR design but only produce them every now and agin when there is enough interest.
Edited by P11 COV, 08 September 2010 - 09:33 PM.
Posted 08 September 2010 - 09:32 PM
Posted 08 September 2010 - 10:28 PM
Posted 09 September 2010 - 06:34 AM
Posted 09 September 2010 - 06:37 AM
the vx was specified with 17" front wheels for aesthetic reasons
Does anybody know where this, often quoted, info came from ? I have seen it on the TMS website but is this actually true ?
Posted 09 September 2010 - 06:38 AM
Posted 09 September 2010 - 08:00 AM
But also for handling (the vx was specified with 17" front wheels for aesthetic reasons - the Lotus varients came with 16" fronts as standard
how does wheel diameter affect handling ?
Posted 09 September 2010 - 08:15 AM
/me grabs the popcorn
I did it for a better selection of pikey tyres, thats it plain and simple.
Posted 09 September 2010 - 08:18 AM
It's not the wheel diameter that affects the handling, it's the tyre profile
Posted 09 September 2010 - 09:01 AM
and the profile of an Elise 175/55 on 16" is massively different from a 175/55 on 17" ?
IIRC the profile is a percentage of the width and not the diameter.
Or am i talkign out my arse ?
Edited by LazyDonkey, 09 September 2010 - 09:01 AM.
Posted 09 September 2010 - 09:06 AM
Edited by Retset, 09 September 2010 - 09:09 AM.
Posted 09 September 2010 - 09:10 AM
ass ?
the xxx / yy are pretty much approximate numbers, but you are correct. usually you can find the exact dimension on the tyres company website if you need more accurate info
but for example , say you switched to much cheaper and lighter wheels and tyre combo
for this it was considered that the smaller rear tyre contact patch was not significant
RE040 , size, diameter mm, rolling radius mm , rim width
front 175/55/17 , 624 , 1903 , 5.5J
rear 225/45/17 , 634 , 1933 , 7.5J
KU31 , size, diameter mm, rolling radius mm , weight lbs, cost ( camskill )
front 195/45/15 , 557 , 1699 , 16.9 , £39
rear 205/50/15 , 587 , 1790 , 19.6 , £45
change in static ride height assumes standard f 140/r 140 to f 107/r 117
front 624-557= 33mm drop
rear 634-587= 23mm drop
rake = 10mm fr to back
rear rolling radius change , 1933/1790 = 8% , also effective 8% more gearing / torque advantage / speedo adj.
Posted 09 September 2010 - 09:13 AM
Edited by LazyDonkey, 09 September 2010 - 09:14 AM.
Posted 09 September 2010 - 09:25 AM
Posted 09 September 2010 - 09:44 AM
Posted 09 September 2010 - 10:07 AM
Edited by SteveA, 09 September 2010 - 10:08 AM.
Posted 09 September 2010 - 10:54 AM
Posted 09 September 2010 - 12:37 PM
And the fact that they always send one car off the racing line for the photo finish. The VX came out the corner ahead, is quicker at accelerating then lost it when veering offline for the finish… the VX would have won had the lotus moved to the right; of that I have no doubt!Even if it does make a difference, the actual amount is negligable.
Fifth gear VXT vs 111r test speaks volumes. There was literaly nothing in it, a few 10th's tops and I recon that's more down to the 111r's higher power to weight ratio.
