Stage 1 Cams Vs Blower Cams
Posted 16 September 2010 - 06:55 PM
i already have the stage 1 cams is it really going to make that much difference.
here are the specs
Stage 1 Cams
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,600-6,800
Intake Duration at 050 inch Lift: 210
Exhaust Duration at 050 inch Lift: 212
Duration at 050 inch Lift: 210 int./212 exh.
Advertised Intake Duration: 252
Advertised Exhaust Duration: 256
Advertised Duration: 252 int./256 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.423 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.419 in.
Valve Lift with Factory Rocker Arm Ratio: 0.423 int./0.419 exh. lift
Lobe Separation (degrees): 111
Blower Cams
Basic Operating RPM Range: 2,800-7,000
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 210 int./218 exh.
Advertised Exhaust Duration: 262
Advertised Duration: 252 int./262 exh.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.436 in.
Valve Lift with Factory Rocker Arm Ratio: 0.423 int./0.436 exh. lift
Lobe Separation (degrees): 113
my revlimit with the new valves etc is going to be 7200rpm, so ideally id need the 7000 revs from the stage 1 cams, but are the other bits much better or what?
Posted 16 September 2010 - 07:01 PM
Posted 16 September 2010 - 07:02 PM
Blower cams were worth 30+bhp on my car.
thats from standard..
i already have 270bhp on stage 2
Posted 16 September 2010 - 07:04 PM
Edited by joe_589, 16 September 2010 - 07:07 PM.
Posted 16 September 2010 - 07:06 PM
Okay. Well, in that case, having them fitted meant I had 285bhp straight away. So a 15bhp increase over your Stage 2 cams at 7000rpm.
Posted 16 September 2010 - 07:07 PM
Edited by joe_589, 16 September 2010 - 07:08 PM.
Posted 16 September 2010 - 07:08 PM
Posted 16 September 2010 - 07:11 PM
Posted 16 September 2010 - 07:15 PM
Posted 16 September 2010 - 07:33 PM
Posted 16 September 2010 - 09:18 PM
Posted 17 September 2010 - 09:03 AM
Posted 17 September 2010 - 09:30 AM
Those durations are not what I measured a pair of comp cams at... I saw 270 duration.
At what lift did you declare the duration to be at?
The yanks tend to use 0.01" of lift as the start/finish of duration, where as us brits tend to go zero to zero (so appear to have longer durations)
Posted 17 September 2010 - 10:25 AM
So maybe there's also a significant difference in timing (position of sprocket pin) between a Stage 1 (for L61) and a blower cams (for the LSJ)
Edited by Exmantaa, 17 September 2010 - 10:25 AM.
Posted 17 September 2010 - 10:42 AM
Edited by siztenboots, 17 September 2010 - 10:46 AM.
Posted 17 September 2010 - 10:47 AM
Posted 17 September 2010 - 01:49 PM
Posted 17 September 2010 - 02:05 PM
I only read here about the cam lobe specs, but is there not a difference in cam timing between the Z22SE (=L61) and the supercharged LSJ engine?
Better specified here: http://www.crateengi...re/PDFS/ECS.pdf
Some specs changed in 2006 in the US engines,but there is a difference in timing NA vs. Supercharged:
The 2006MY L61 cams (=Z22SE?) can interchange with LSJ cams, both intake and exhaust. These cams are
the exact same profile, only at different timings. The 2006MY L61 timings are 116 intake, -103
exhaust. The LSJ timings are 100 intake, -115 exhaust.
Edited by Exmantaa, 17 September 2010 - 02:10 PM.
Posted 10 March 2012 - 09:30 PM
