"Drive By Wire" Problem
20 replies to this topic
#1 muckyman
muckyman
  • 340 posts
  • Interests:Barmaids
Posted 01 October 2010 - 10:06 AM
Hi all, Over the past month or so my accelerator pedal has stopped responding twice. The first time was on start up and after the connection at the pedal was disconnected and reconnected it was fine. This morning it went again in slow moving traffic and a simple switch off and restart solved the problem. Obviously, I'm concerned if I were to lose the accelerator while driving at speed. What could be causing this? The connection at the pedal seems fine Ta Michael
#2 smiley
Posted 01 October 2010 - 10:10 AM
Ah, the loom of doom :closedeyes: 1st step = Contactspray on connector at throttle padle, same at connectors under cooling header tank (the blue connector), and the same at the connector at the throttle body. If still fails after that, the connector under the collingheader tanks may need some pins rebuild.
#3 muckyman
muckyman
  • 340 posts
Posted 01 October 2010 - 10:13 AM
Cheers for the advice. Not come across contact spray before, is it a specific product or would something like WD40 do the job? (also, is this a known problem?)
#4 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 01 October 2010 - 10:15 AM
Halfords "electrical contact cleaner" tis in a yellow can
yes known problem
Edited by NickB777, 01 October 2010 - 10:16 AM.
#5 muckyman
muckyman
  • 340 posts
Posted 01 October 2010 - 10:21 AM
Cheers, final question. When you say the connector under the cooling header tank, is that the expansion tank looking thing at the passenger side of the engine bay? If so, is the connection easy to get to or does the tank have to be removed etc etc (want to fix it today but it's pi$$ing down outside and I don't want to start a long job) Ta again
#6 CHARL13
CHARL13
  • 536 posts
Posted 01 October 2010 - 10:37 AM
If it's the connector I'm thinking of, it's sooooo much easier to take the wheel off and arch liner out. thumbsup If you do go down that route can I be cheeky and ask a favour? I'm after a couple of pictures of the wires going on and out of that connector?
#7 FLD
Posted 01 October 2010 - 11:17 AM
This is a reasonably common problem. I'd recomend checking all the wiring plugs first. Given you've done the pedal try the throttle body and the two behind the header tank too. Its also worth checking the terminals are tight in the ones behind the header tank. Any movement in the wiring opens up the terminals. Open the plug, pull off the yellow grill and look in. You'll see the clamp part of the terminal and you should be able to tell if one is opened slightly. If it is close it back up with a pin. Reassemble but then immobilise the wiring with cable ties so it doesn't happen again. Yeah, this takes a while so best not try it today but do it soon as you'll suddenly end up with nothing at all.
#8 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 01 October 2010 - 11:24 AM
The electrical connections on the ecu getting wet can cause this too!
#9 smiley
Posted 01 October 2010 - 11:28 AM
:yeahthat: My throttle died after a rainy day. Still need to make a sort of rain deflector shield like the tubby has for my throttle section.
#10 badgerade
badgerade
  • 1,173 posts
Posted 01 October 2010 - 11:29 AM
Yep this is what was causing my throttle problems - was getting various error codes until Vocky pulled the loom apart for the ITB conversion. The 'waterproof' plug had got a load of water in and quite a few of the pins had completely corroded away.
I can understand where you're coming from when you say you don't want to drive it - I had complete loss of throttle which nearly resulted in an Audi wedging itself in the rear clam, and another instance when I lost power in the outside lane of the M4.
#11 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 01 October 2010 - 11:35 AM
Mine did this after the deluge at the last LoT Silverstone day.
#12 muckyman
muckyman
  • 340 posts
Posted 01 October 2010 - 11:46 AM
Bl00dy hell, lots of things to check and I ain't even got a jack to get the wheel off! Trip to Halfords I think. By the way, where is the ecu again? Might as well check everything.
#13 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 01 October 2010 - 11:49 AM
mounted near the coolant bottle chinky chinky
i have none in mine :P i mean doesn't live there no more
#14 techieboy
Posted 01 October 2010 - 11:55 AM
Depends on which variant you have and just how modified it might be?
#15 muckyman
muckyman
  • 340 posts
Posted 01 October 2010 - 12:02 PM
It's a fairly standard n/a. If anyone has any photos of the locations of the connectors that need looking at, including the ecu, I would be very grateful Ta Michael
#16 VIX
VIX
  • 9,497 posts
Posted 01 October 2010 - 12:28 PM
Ta
Michael
I'd be very surprised if this is not covered in the TIS which is linked in the noobs section.
#17 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 01 October 2010 - 12:40 PM
:lol:
#18 CHARL13
CHARL13
  • 536 posts
Posted 01 October 2010 - 12:43 PM
I'm doing the exact same thing so i'll try and take some snaps.
#19 muckyman
muckyman
  • 340 posts
Posted 01 October 2010 - 12:57 PM
Cheers
(from a noob)
#20 CHARL13
CHARL13
  • 536 posts
Posted 01 October 2010 - 04:35 PM
Well here's some pics.
The 2 connectors behind the header tank, I would look at these first as the ECU connectors are a complete pig to get off.
With the yellow grill removed
The ECU
A close up of the ECU
The ECU connector removed
