Reference: Front Wheel Drive Gearbox ST90-14 >> PDF
TECHNICAL DETAILS :
· 6 speed dog ring gearbox, with sequential gearing
· Different final drives available
· Variable ratios
· Gear teeth are 14mm wide, straight cut on 90mm centres
· Splash lubrication, with cooling circuit pump and suction filter
· Front self-locking differential with a choice of ramp angles and preload settings
· Design for 2L and 3L engines, up to 350 N.m (250 lbs/ft) engine torque
· Clutch release slave cylinder (Sadev specific one) is included
· Clutch shaft to suit customer installation is included
· Weight : 42,5 kg
OPTIONAL :
· Gear lever with neutral reverse cable
· Gear display
· Specific bell housing
GEAR RATIOS : See >>PDF-file
DIMENSIONS and EXPLODED VIEW: See >> PDF-file
Plus
For 2L Fiat engine ( Alfa 147 ):
Clutch housing marketed by N Technology Ref : 572 65 47
