My Central Locking Doesn'T
Posted 04 October 2010 - 05:35 PM
Posted 05 October 2010 - 09:59 AM
Posted 05 October 2010 - 03:11 PM
Posted 05 October 2010 - 04:28 PM
Posted 05 October 2010 - 11:09 PM
Posted 03 April 2011 - 08:11 AM
I have a VXT that has taken to refusing to lock. The alarm arms but the doors don't lock, the pins give a little twitch but nothing more.
I can push the pins down manually and the door locks OK but not remotely or with the switch on the steering column.
I'm a bit stuck now because there isn't anywhere to stick the key to lock manually.
Any ideas?
Phil.
Sorry to bring back an old thread but I thought it was better than starting a fresh.
My car has develped the exact same problem. Can anybody help with how to fix it?
I also found this other thread >HERE< but that's the opposite of my problem. It talks about replacing the CDL module under the dash. Not sure if that could be it?
If I push the door pin down manually to lock then the remote or the steering column switch will unlock it ok. Would I be doing any harm pushing the button down to lock it in the meantime as there feels like some resistance there?
Posted 03 April 2011 - 10:41 AM
Edited by Wolfstone, 03 April 2011 - 10:47 AM.
Posted 03 April 2011 - 03:59 PM
Posted 04 April 2011 - 03:23 PM
Posted 05 April 2011 - 12:50 AM
Posted 05 April 2011 - 08:14 AM
NAs don't have this problem
Thanks for the advise
Posted 08 April 2011 - 10:09 AM
Posted 08 April 2011 - 04:32 PM
Posted 09 April 2011 - 12:01 AM
It does sound like the CDL module is not working properly to me
Thanks a lot for the reply. I've seen them around £51 any idea if possible to get one cheaper, seems a bit steep? Maybe a vauxhall part number instead of the Lotus one is available?
That's assuming it is this part that's at fault. Looks like a bit of a pita to change though as the whole dash has to be taken to pieces according to the other thread link.
Posted 09 April 2011 - 08:48 AM
Posted 10 April 2011 - 10:22 AM
Well if you want to rule everything else out it may be worth taking the door cards off one door and checking the wiring. As far as I recall, the CDL just swaps the polarity of two wires to the lock motor if it is a two wire motor, or if three wire there is a common, lock and unlock feed. Just check with a multimeter that power is getting to the motors, and that the correct polarity/ wire has power when locking/unlocking. TIS is your friend for a wiring diagram
Thanks for the info. I don't have a multimeter but maybe I can find a mate with one to test it for me.
Posted 02 February 2013 - 09:10 PM
Posted 02 February 2013 - 09:32 PM
I have the same problem, car wont lock from the fob after changing both batteries. Did you manage to fix it with the CDL change in the end?
Yes got a new cdl module. Luckily off a lotus guy who bought the part but had traded his car before fitting so got it new still sealed in the lotus bag. Think cost me the bargain price of £20.
Most interestly I had the idea to try it (& my expert car fixing mate managed) to change it through the light switch opening without all the dash take apart mullarky that everybody says is needed. I have had to leave the original in there as its bolted down but such a small unit weighs nothing extra. We stuck the new one on top of the original. Job done in 10 mins & working again a treat.
Hope that helps
Posted 02 February 2013 - 11:41 PM
Posted 03 February 2013 - 08:15 AM
