Bigger Brakes
Posted 16 October 2010 - 01:21 PM
Posted 16 October 2010 - 02:35 PM
Posted 16 October 2010 - 03:22 PM
Posted 17 October 2010 - 07:30 AM
I have astra gsi 308mm discs on mine,but you need 10mm spacers for the calipers and 10mm longer bolts to hold the caliper to the hub
4 pots are not really required on the vx220, just decent pads like mintex 1144 / 1155 or equivilant
hactually its more than 10mm of spacers
Posted 17 October 2010 - 07:55 AM
Alcon / AP 295mm (Plans told me they were AP discs but I don't think they are, I think they are Alcon) up front on mine and spacers, RS4-2 Pads all round and braking is great
Alcon have a small moon shape instead of grooves
Posted 17 October 2010 - 08:02 AM
Posted 17 October 2010 - 05:56 PM
hactually its more than 10mm of spacersWell I had to put more than 10mm of spacer onto mine when I tried the 308's (incidentally the 308's weigh as much as the vx and offered next to shag all difference imho)
So wouldn't recommend going to 308mm's then just a decent set of discs and pads? Groved only or drilled and groved? cracking a poblem?
Cheers
IAN J
Posted 17 October 2010 - 07:15 PM
Posted 18 October 2010 - 07:18 PM
unless the 'drillings' are cast in the disc then I wouldnt touch a drilled disc with a billion foot long barge pole
depending on what you are doing with the car, the usual brake recipe works... plain pikey £20 a shot std discs and for pads Mintex 1144/1155/ carbon lorane CL5+ or somethings... depends on your budget etc.
The car is running about 250 bhp and on 888's with comps, braided hoses, redstuff but standard discs. I am getting the suspension sorted but brakes are frankly SH1 T on the track, hence want more.
The spacer idea worked for me before and you can get GSI or other 308mm vauxhall performance discs for £80. Some are worried about the spacer format, but elise shop sell them? Any ideas or concerns?
rgds
IAN
Posted 18 October 2010 - 07:31 PM
Posted 18 October 2010 - 08:00 PM
rgds
IAN
I have EP spacers so I can run these :-
http://www.elisepart...ap-brake-discs/
295mm discs, and no concerns in any way. Fantastic brakes with pagids.
Posted 18 October 2010 - 08:20 PM
Posted 19 October 2010 - 09:06 AM
redstuff
there is your problem...
Posted 19 October 2010 - 09:37 AM
redstuff ........ but brakes are frankly SH1 T
You've answered your own question. There's so much good stuff on here, why you want to plough your own furrow is a mystery to me. Standard discs - good pads SEOT
Posted 19 October 2010 - 09:51 PM
Edited by Tail slide, 19 October 2010 - 09:51 PM.
Posted 21 October 2010 - 09:47 PM
Click here
Update to add I now run cl5+, love them but need to have them with the sticky bond stuff to stop the rattle.
Posted 21 October 2010 - 11:15 PM
Posted 22 October 2010 - 05:38 AM
Fcuk me, a thread about brakes. You'd think this would've been covered before!
standard size disk CL5+ = great
Edited by NickB777, 22 October 2010 - 05:42 AM.
Posted 22 October 2010 - 08:16 AM
I have the same setup as you with CL5+ pads and the brakes on track are awesome.
