hello
neil came round again today, happy to say the car is now starting up and running
but.....the car does need a camshaft sensor which i have orderd and will be here thursday, here is a list which we got on neils computer when he plugged it in, can anyone tell me what these problems are and how to fix them? i would like to say the car is not 100% complete yet, doors are not on, rear lid is not on, no water in yet, charge cooler is not fully connected up and a few other little bits and bobs im sure but the major things are connected for it to start and run.
P0115-coolant sensor cuircuit high input
P1105-boost pressure sensor short ground
P1106-boost pressure sensor test
P0530-airco pressure sensor voltage high
P0135-o2 heater circuit open
P1530-airco relay open circuit
P0135-o2 heater circuit malfunction
P030-can position sensor circuit high input
anyone help out with these? also would anyone know if the camshaft sensor is the same on the z20lets as it is on the c20let engines? as i could get one from a c20let engine tonight but if not i will order a new one from autovaux
thank,adam
